setField not working while trying in on an imported geometry |
November 28, 2020, 13:26 |
Deutschland
Rep Power: 5 |
hey,
I am trying to apply setFields on https://drive.google.com/file/d/10BI...ew?usp=sharing , a background mesh created using Salome and it is not working. the new alpha.water field file is not being created (No error message is shown in the terminal). following is my setFieldDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( boxToCell { box (1 -0.8271 -0.601) (1 -0.8271 0); fieldValues ( volScalarFieldValue alpha.water 1 ); } ); // ************************************************************************* // Thank you in advance Kind regards vava10 |
November 28, 2020, 17:37 |
Rep Power: 5 |
Please double check the coordinates of 'box'. These coordinates define the region for which you want to set alpha.water to 1. In other words, alpha.water value is set to 1 only for cells that their centre lie in the defined box region. In your 'setFieldDict' file, 'box' is defined as a line from z = (1, -0.8271, -0.601) to z = (1, -0.8271, 0). Cheers |
November 29, 2020, 08:31 |
Deutschland
Rep Power: 5 |
Hey Rango,
when I searched the syntax of boxToCell the syntax came up as box (<minX> <minY> <minZ>) (<maxX> <maxY> <maxZ>); I thought it was supposed to be from minimum point ti maximum point till I have set alpha.water as 1. I think I might be wrong Can you help? Kind regards vava10 |
November 29, 2020, 09:48 |
Rep Power: 5 |
The syntax is fine. The dimensions of the box might be the issue. Size of the bounding box is equal to |(maxX - minX) * (maxY - minY) * (maxZ - minZ)|, which in your case is zero! I have attached a simple schematic of 'box' dimensions. Hope this makes it more clear for you. Cheers Last edited by Rango; November 29, 2020 at 13:02. |
[DesignModeler] Regarding error in edges in imported 3D geometry | msd | ANSYS Meshing & Geometry | 0 | November 20, 2020 10:54 |
Surface Faces from imported geometry | Miguel Parente | STAR-CCM+ | 4 | November 1, 2017 22:49 |
[DesignModeler] Creating a body part from an imported geometry | tec | ANSYS Meshing & Geometry | 0 | July 27, 2015 07:09 |
[Salome] how to create geometry with salome to make "IdeasUnvToFoam" working! | amorenelchino | OpenFOAM Meshing & Mesh Conversion | 5 | June 24, 2013 10:35 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
