January 27, 2021, 10:21 |
Radiation boundary conditions
Fabian Friberg
Rep Power: 5 |
My case uses a viewFactor radiation model combined with the solarLoad library (OFv2012) to calculate qr at the boundaries. I'm trying to get the right boundary conditions for 0/T to translate this into temperatures in the internal mesh.
The tutorials use compressible::turbulentTemperatureRadMixed as their BCs, but it seems to only be for multi-region cases. Mine is not. Then I looked at externalWallHeatFluxTemperature, and greyDiffusiveRadiationViewFactor. The latter one seemed to fit my case the most. I'm unsure about what the parameters mean exactly though. This is my current setup: Code:
type greyDiffusiveRadiationViewFactor; emissivityMode lookup; qro uniform 0.5; value 0.5; But then what does qro stand for? And what does value stand for? I'm guessing value stands for the starting value for qr, but then what is qro? I've tried different values, but either I get division by zero or FOAM FATAL ERROR: Negative initial temperature after a few iterations. How should I configure my BCs? Thanks. |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Radiation Modeling | Chris89 | CFX | 20 | August 14, 2014 07:51 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
