February 1, 2021, 07:36 |
perturbU utility for non-Newtonian flow
Nat K
Rep Power: 8 |
I have been working on Newtonian turbulent channel flow, by means of DNS, with some success. However, I am interested in non-Newtonian turbulent channel flow now, but I am having some difficulties in triggering transition to turbulence. For the Newtonian cases, I had used perturbU utility to introduce streaks to a turbulent velocity profile, which then develops into a nice turbulent flow field. However, when I do this with a non-Newtonian case, the perturbations die out. I'm curious whether anyone else has tried a turbulent non-Newtonian flow simulation using perturbU, and encountered the problems I have. Thanks. |
February 9, 2021, 16:07 |
Rep Power: 9 |
I do not know about your issue, however, if possible then please let me about Newtonian DNS case. Have you obtained the comparison with benchmark solutions. I am trying this case but my solutions do not converge.
February 9, 2021, 16:15 |
Rep Power: 9 |
By the way, can you share your perturbU. I think there is some problem with your perturbU.
February 9, 2021, 16:51 |
Herpes Free Engineer
Rep Power: 12 |
I wouldn't use OpenFOAM for DNS in the first place, honestly - OpenFOAM should be very slow for DNS. Academic software such as http://channelflow.org/ should be a much better alternative.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 10, 2021, 10:37 |
Rep Power: 9 |
Yes, OF is expensive. I know some in-house codes are available for DNS channel flow case and can be used for getting the benchmark solutions.
But just for learning, I was doing it with OF. |
Will the results of steady state solver and transient solver be same? | carye | OpenFOAM Running, Solving & CFD | 9 | December 28, 2019 05:21 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
Non Newtonian Flow | sunil chandel | FLUENT | 1 | July 11, 2007 02:12 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
