February 6, 2021, 18:17 |
Creating .C file
Skanda
Rep Power: 5 |
Hey just started OpenFOAM. I made a dummy file for a k0omegaSST.C and made some changes on it. How can I run it to see if the changes I made are correct or not? The changes that I made have also been specified in the .H file.
February 10, 2021, 11:49 |
Agustín Villa
Rep Power: 15 |
Hi Fuzzy_Wuzzy
you will need to compile this turbulence model in order to test it and validate your changes. You can check several tutorials around about how to do this. Cheers |
February 10, 2021, 15:08 |
Skanda
Rep Power: 5 |
Hey thank you, so I have to make a PANS model with zonal approach for my thesis and I have added all the required variable to the kOmegaSST base file and then I know I have to validate this so my question is do I use wmake or Allmake and what is the difference between the two?
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
