[Sponsors] | |||||
turn off viscus heating in thermophysicalProperties |
yahya rezvani
Rep Power: 8 ![]() |
Hello. i want use openfoam to solve laminar viscos fluid with rotating wall. my problem solved in fluent by turn off viscous heating and use simple scheme for Coupling scheme & use heat source in rotating wall instead of viscus heating. but in openfoam i get error of inital temprarure.
this is my setting: Code:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(U) cellLimited Gauss linear 1;
divSchemes
div(phi,alpha) Gauss interfaceCompression vanLeer 1;
div((((alpha.air*thermo:rho.air)*nuEff.air)*dev2(T(grad(U))))) Gauss linear;
div((((alpha.polymer*thermo:rho.polymer)*(thermo:mu.polymer|thermo:rho.polymer))*dev2(T(grad(U))))) Gauss linear;
div(((alpha.polymer*thermo:rho.polymer)*sigma.polymer)) Gauss linear;
div((((alpha.polymer*thermo:rho.polymer)*nuM)*grad(U))) Gauss linear;
div(rhoPhi,U) Gauss linearUpwindV grad(U);
div(rhoPhi,K) Gauss upwind;
div((phi+meshPhi),p) Gauss upwind;
div(rhoPhi,T) Gauss linearUpwind grad(T);
div(alphaRhoPhi.polymer,sigma.polymer) Gauss linearUpwind grad(sigma);
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited corrected 0.33;
interpolationSchemes
default linear;
snGradSchemes
default limited corrected 0.33;
thermoType
type heRhoThermo;
mixture pureMixture;
transport WLF;
thermo hConst;
equationOfState rPolynomial;
specie specie;
energy sensibleEnthalpy;
mixture
specie
molWeight 291.3;
equationOfState
C (0.005218 -3.1055e-06 4.8689e-09 5.7772e-13 -3.2225e-16);
thermodynamics
Cp 1800;
Hf 0;
transport
mu0 53763179097.64641453;
Tr 115;
C1 31.24;
C2 107.53;
Pr 6.15;
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: solidBody
Selecting solid-body motion function rotatingMotion
Applying solid body motion to cellZone propellerStem
PIMPLE: No convergence criteria found
PIMPLE: No corrector convergence criteria found
Calculations will do 2 corrections
PIMPLE: Operating solver in transient mode with 2 outer correctors
Reading field p_rgh
Reading field U
Constructing twoPhaseMixtureThermo
Selecting thermodynamics package
type heRhoThermo;
transport WLF;
thermo hConst;
specie specie;
type heRhoThermo;
transport const;
thermo hConst;
equationOfState rhoConst;
specie specie;
energy sensibleInternalEnergy;
Reading thermophysical properties
Reading g
Reading hRef
Calculating field g.h
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Creating field kinetic energy K
No MRF models present
Creating finite volume options from "system/fvOptions"
Selecting finite volume options model type limitTemperature
Source: limitT
- selecting all cells
- selected 1131591 cell(s) with volume 0.0005971852225
Courant Number mean: 0.001553287087 max: 0.06698099517
Constructing face velocity Uf
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.001199040767
Time = 0.00119904
PIMPLE: Iteration 1
smoothSolver: Solving for alpha.polymer, Initial residual = 4.148307397e-07, Final residual = 4.148307397e-07, No Iterations 0
Phase-1 volume fraction = 0.2935706537 Min(alpha.polymer) = 0 Max(alpha.polymer) = 1
MULES: Correcting alpha.polymer
DILUPBiCGStab: Solving for T, Initial residual = 0.7538694576, Final residual = 7.468251956e-07, No Iterations 59
DICPCG: Solving for p_rgh, Initial residual = 0.9999999577, Final residual = 14.02207328, No Iterations 1000
PIMPLE: Iteration 2
smoothSolver: Solving for alpha.polymer, Initial residual = 0.0001202851214, Final residual = 9.627369821e-07, No Iterations 18
Phase-1 volume fraction = 0.2935690002 Min(alpha.polymer) = 0 Max(alpha.polymer) = 1
Phase-1 volume fraction = 0.2935690002 Min(alpha.polymer) = -0.1114075347 Max(alpha.polymer) = 1.245386626
DILUPBiCGStab: Solving for T, Initial residual = 0.2150890754, Final residual = 3.474027855e-07, No Iterations 169
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 ? in "/lib/x86_64-linux-gnu/libm.so.6"
#4 exp in "/lib/x86_64-linux-gnu/libm.so.6"
#5 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::WLFTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rPolynomial<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#6 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::WLFTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rPolynomial<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:?
#7 Foam::twoPhaseMixtureThermo::correctThermo() at ??:?
#8 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? in "/opt/openfoam8/platforms/linux64GccDPInt32Opt/bin/compressibleInterFoam"
Floating point exception (core dumped)
best regards. |
atilla altintas
Rep Power: 17 ![]() |
It could be a bit late but I had a similar problem and solved it with below change in the thermophysicalProperties dictionary: thermoType { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } changed to: thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Sudden stop of heating - convergence problem? | PSander | OpenFOAM Running, Solving & CFD | 0 | February 2, 2021 05:34 |
| Comparison of under-floor heating and radiator heating | Mountainbike | OpenFOAM Running, Solving & CFD | 1 | November 27, 2020 07:55 |
| Viscous Heating | aeroramji@gmail.com | FLUENT | 0 | January 10, 2017 02:20 |
| is it possible to modelize induction heating in a frequency domain with OpenFOAM? | julien23 | OpenFOAM | 0 | January 12, 2015 06:47 |
| Heating value of fuel in non-premixed model? | Jeronimo97 | FLUENT | 0 | February 15, 2013 15:27 |
