Issue related to Constant heat flux Boundary condition
I want to specify constant heat flux Boundary condition as below and i have two questions
1. what are the difference between externalWallHeatFluxTemperature and fixedGradient BC? 2. I am getting some error for below BC Wall { type externalWallHeatFluxTemperature; mode flux; q uniform 1446; // (q = W/m^2) kappaMethod fluidThermo; kappa none; kappaMethod fluidThermo; value $internalField; // type fixedGradient; // gradient uniform 55223; //{ DT/Dn = q (w/m^2) / K_air (W/m-K) = 1446/0.026 = 55223 } } It is showing below error in OF8 "--> FOAM FATAL ERROR: Cannot find a fluidThermo or solidThermo instance From function Foam::tmp<Foam::Field<double> > Foam::temperatureCoupledBase::kappa(const fvPatchScalarField&) const in file derivedFvPatchFields/temperatureCoupledBase/temperatureCoupledBase.C at line 133." FOAM exiting Thanks |
Maybe it doesn't matter since it should skip the second one, but try removing the duplicate "kappaMethod fluidThermo;" row?
You might be trying to use it with a solver that is not using solid or fluidThermo.
