combustion->correct()
Do you know what does the following code in OF stand for? Code:
combustion->correct() |
It means a "correct()" function in "combustion" instance is called. To know what exactly it means, we have to know the definition of "combustion". Could you tell us the version of OpenFOAM and the name of solver you are looking. Putting clear and concise information will increase the probability of the desired help occurring. |
Thank a lot for the reply. I am using Openfoam 2.1 and the solver ddtFoam. |
The correct() function is declared in combustionModel.H (https://cpp.openfoam.org/v8/combusti...8H_source.html) and then implemented in the RTS selected model, eg EDC (https://cpp.openfoam.org/v8/EDC_8C_source.html). Try the search function in the Doxygen pages - that should help you answer these questions for yourself in the future. Good luck!
