No interfaces between the solid and fluid after splitMeshRegions
Old   September 17, 2021, 08:39
Default No interfaces between the solid and fluid after splitMeshRegions
a
a2019 is on a distinguished road
Hi All,
I am very new to OpenFoam and trying to run the case with chtMultiRegionFoam. The case is very simpele geometrically (fluid layer "r4" between the solid layers). The mesh is created by blockMesh and then command splitMeshRegions -cellZones -overwrite is used. The problem is that the interface is not created between the fluid and solid regions. How to deal with this problem?
blockMeshDisct:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  9
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
r1_depth0 10;
r2_depth0 180;
r3_depth0 15;
r4_depth0 28;
r5_depth0 100;
r4_width0 45;
case_width #calc " 2 * $r4_width0 ";
case_height 21; //75;
r2_depth #calc " $r2_depth0 + $r1_depth0 ";
r3_depth #calc " $r3_depth0 + $r2_depth ";
r4_depth #calc " $r4_depth0 + $r3_depth ";
r5_depth #calc " $r5_depth0 + $r4_depth ";
bcs 3;
bcf 1;
ratio 1.5;
nnw #calc " ceil( $case_width / $bcs ) ";
nnh #calc " ceil( $case_height / $bcs / $ratio) ";
nn_r1 #calc " ceil( $r1_depth0 / $bcs ) ";
nn_r2 #calc " ceil( $r2_depth0 / $bcs ) ";
nn_r3 #calc " ceil( $r3_depth0 / $bcs ) ";
nn_r5 #calc " ceil( $r5_depth0 / $bcs ) ";
nn_r4 #calc " ceil( $r4_depth0 / $bcf ) ";
convertToMeters    0.001;
vertices
// r1
  (0            0           0)  // vert 0
  ($r1_depth0 0           0)  // vert 1
  ($r1_depth0 $case_width 0)  // vert 2
  (0            $case_width 0)  // vert 3
  (0            0           $case_height)  // vert 4
  ($r1_depth0 0           $case_height)  // vert 5
  ($r1_depth0 $case_width $case_height)  // vert 6
  (0            $case_width $case_height)  // vert 7
// r2
  ($r1_depth0 0           0)  // vert 8
  ($r2_depth  0           0)  // vert 9
  ($r2_depth  $case_width 0)  // vert 10
  ($r1_depth0 $case_width 0)  // vert 11
  ($r1_depth0 0           $case_height)  // vert 12
  ($r2_depth  0           $case_height)  // vert 13
  ($r2_depth  $case_width $case_height)  // vert 14
  ($r1_depth0 $case_width $case_height)  // vert 15
// r3
  ($r2_depth 0           0)  // vert 16
  ($r3_depth 0           0)  // vert 17
  ($r3_depth $case_width 0)  // vert 18
  ($r2_depth $case_width 0)  // vert 19
  ($r2_depth 0           $case_height)  // vert 20
  ($r3_depth 0           $case_height)  // vert 21
  ($r3_depth $case_width $case_height)  // vert 22
  ($r2_depth $case_width $case_height)  // vert 23
// r4
  ($r3_depth   0           0)  // vert 24
  ($r4_depth 0           0)  // vert 25
  ($r4_depth $case_width 0)  // vert 26
  ($r3_depth   $case_width 0)  // vert 27
  ($r3_depth   0           $case_height)  // vert 28
  ($r4_depth 0           $case_height)  // vert 29
  ($r4_depth $case_width $case_height)  // vert 30
  ($r3_depth   $case_width $case_height)  // vert 31
// r5
  ($r4_depth   0           0)  // vert 32
  ($r5_depth      0           0)  // vert 33
  ($r5_depth      $case_width 0)  // vert 34
  ($r4_depth   $case_width 0)  // vert 35
  ($r4_depth   0           $case_height)  // vert 36
  ($r5_depth      0           $case_height)  // vert 37
  ($r5_depth      $case_width $case_height)  // vert 38
  ($r4_depth   $case_width $case_height)  // vert 39
// plaster
blocks
    // Fluid regions
    hex (24 25 26 27 28 29 30 31) r4 ($nn_r4 $nnw $nnh) simpleGrading (1 1 1)
    // Solid regions
    hex ( 0  1  2  3  4  5  6  7) r1 ($nn_r1 $nnw $nnh) simpleGrading (1 1 1)
    hex ( 8  9 10 11 12 13 14 15) r2 ($nn_r2 $nnw $nnh) simpleGrading (1 1 1)
    hex (16 17 18 19 20 21 22 23) r3 ($nn_r3 $nnw $nnh) simpleGrading (1 1 1)
    hex (32 33 34 35 36 37 38 39) r5  ($nn_r5  $nnw $nnh) simpleGrading (1 1 1)
boundary
    inlet
        type patch;
        faces
          (24 25 27 26)
    external
        type patch;
        faces
            (0 3 7 4)
            (33 34 38 37)
    walls
        type wall;
//        inGroups (externalWall);
        faces
           (17 18 22 21)
    outlet
        type patch;
        faces
          (28 29 30 31)
mergePatchPairs
splitMeshRegions outprint:
Region    Zone    Name
0    0    r1
1    1    r2
2    2    r3
3    3    r4
4    4    r5
Sizes of interfaces between regions:
Interface    Region    Region    Faces
Reading geometric fields
Reading volScalarField cellToRegion
a2019 is offline   Reply With Quote
[solids4Foam] How to calculate drag coeff when using solids4Foam amuzeshi OpenFOAM CC Toolkits for Fluid-Structure Interaction 15 November 7, 2019 13:50
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
