codedFixedValue not assigning values to the inlet |
October 13, 2021, 11:49 |
Rep Power: 4 |
I'm new to OpenFOAM and trying to simulate a flow in a channel to learn OpenFOAM. I'm running multiphase (water and air) case so I would like to assign flowrate where alpha.water is 1 (which is z<=0.8 in my case. I used the following code in my 0/U file but nothing is happening to the model. Can someone who has experience with codedFixedValue chime in on this? I would appreciate the help. Thanks. Here in the inlet BC from 0/U file Code:
inlet { type codedFixedValue; value uniform (0 0 0); name inletBC; code #{ const fvPatch& boundaryPatch = patch(); const vectorField& Cf = boundaryPatch.Cf(); vectorField& field = *this; forAll (Cf, faceI) // loop over all the patch faces { const scalar x = Cf[faceI].x(); // y coordinate of the face const scalar y = Cf[faceI].y(); // y coordinate of the face const scalar z = Cf[faceI].z(); // y coordinate of the face if (z <= 0.80 && y <= 2 && x <=0.1 ) { field[faceI] = vector(1, 0, 0); } else { field[faceI] = vector (0, 0, 0); } } #}; } |
codedfixedvalue, interfoam, openfoam |
Assigning values from 2d double array to Field<Type> | yousefaz | OpenFOAM Programming & Development | 0 | June 2, 2021 20:23 |
Assigning values to read-only location | saumavadey | OpenFOAM Running, Solving & CFD | 0 | February 10, 2021 08:20 |
How can we use dimensionless values as inlet and out let BC? | granzer | FLUENT | 3 | November 7, 2019 23:29 |
Assigning values to a cartesian grid from a binary image (or stl) | Cyp | OpenFOAM Pre-Processing | 1 | August 5, 2014 18:02 |
units for inlet values of contaminant in star-ccm+ | judge | Siemens | 0 | August 13, 2008 07:29 |
