Boundary conditions
Old   October 23, 2021, 17:28
Default Boundary conditions
manou mouna
mannou is on a distinguished road
Hi openfoamers
I would like to study the flow at rest in a tube and I want to specify at the inlet a pressure equal to 0 and for the velocity I want it to adapt with the pressure without assigning a value, how I can define the boundary conditions (inlet) for speed? any help will be appreciated
mannou is offline   Reply With Quote
Old   October 24, 2021, 04:39
manou mouna
Is there anyone who worked in this case please ??
Old   October 25, 2021, 03:48
Lorenzo
Lorenzo210 is on a distinguished road
Try this:
https://www.openfoam.com/documentati...ctorField.html
Lorenzo210 is offline   Reply With Quote
Old   October 29, 2021, 12:31
sqek is on a distinguished road
More generally, for any field where you want the solver to adapt it instead of forcing a value, use zeroGradient.
zeroGradient sets the boundary value equal to the neighbouring cell when updated, so basically doesn't try to change the value and lets the cell decide it itself.
For velocity, pressureInletOutletVelocity can be more stable - it's the same as zeroGradient for outflow, but for inflow it sets a tangential velocity (so if you set tangential velocity to zero, it forces inflow to be perpendicular to the boundary).
There are also some derived versions like pressureNormalInletOutletVelocity (for inflow, velocity is always normal to the boundary)
But if you want the direction of any flow into your tube to not be constrained, use zeroGradient, if this gives weirdness near the edges or is unstable try one of the pressureInletOutletVelocity ones instead.
sqek is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
