November 19, 2021, 02:15 |
Bubble Column by using TwoPhaseEulerFoam
shohei sasaki
In 0/alpha.air, the inlet gas fraction is set to a fixed value of 0.5.
Is this value chosen independently from the other simulation parameters? Or is it related to some other constant, say U.air? |
November 30, 2021, 08:27 |
matej forman
Rep Power: 17 |
No sure what is your question, but I will try and please let me know if I hit it.
alpha.air is the concentration of the air on the inlet. The rest is the water as a carrying liquid to the air bubbles. U.air is a velocity at inlet. You do not need to multiply it by the alpha.air to get the bubble velocity. |
bubble column, initial conditions. |
Display Modes | |
twoPhaseEulerFoam bubble column crashes due to problems at outlet region | hester | OpenFOAM Running, Solving & CFD | 4 | May 18, 2016 11:20 |
Problem: bubble column with twoPhaseEulerFoam | hester | OpenFOAM Running, Solving & CFD | 6 | January 22, 2016 13:25 |
Turbulence modelling for bubble column in twoPhaseEulerFoam | hester | OpenFOAM Running, Solving & CFD | 2 | February 10, 2015 12:42 |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 20, 2014 00:42 |
twoPhaseEulerFoam Simulations of bubble column | vishal3 | OpenFOAM | 1 | July 7, 2014 05:12 |
