Boundary file in polymesh folder doesn't have the wanted patches
Old   April 17, 2022, 13:58
Default Boundary file in polymesh folder doesn't have the wanted patches
Haroun
Haroun is on a distinguished road
I have a system composed of two injectors and one mixing room. I really struggle to just set a flow through one of the injectors.
Basically, my problem (for now) is that the 'Boundary' file in the 'Polymesh' folder only have the default boundary set in the blockMeshDict. Here is exactly what I did :
I first generated the blockMesh bloc slightly bigger than my geometry :
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 8
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-60 -60 -10) /* 0 */
(60 -60 -10) /* 1 */
(60 60 -10) /* 2 */
(-60 60 -10) /* 3 */
(-60 -60 223) /* 4 */
(60 -60 223) /* 5 */
(60 60 223) /* 6 */
(-60 60 223) /* 7 */
blocks
hex (0 1 2 3 4 5 6 7) (8 8 16) simpleGrading (1 1 1)
edges
boundary
front
type symmetryPlane;
faces
(3 7 6 2)
back
type symmetryPlane;
faces
(1 5 4 0)
inlet
type patch;
faces
(0 4 7 3)
outlet
type patch;
faces
(2 6 5 1)
lowerWall
type wall;
faces
(0 3 2 1)
upperWall
type symmetryPlane;
faces
(4 5 6 7)
Then I ran surfaceFeatures :
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object surfaceFeaturesDict;
inlet_eau
surfaces ("inlet_eau.stl");
includedAngle 150;
subsetFeatures
nonManifoldEdges no;
openEdges yes;
inlet_air
surfaces ("inlet_air.stl");
includedAngle 150;
subsetFeatures
openEdges yes;
wall
surfaces ("wall.stl");
includedAngle 150;
subsetFeatures
openEdges yes;
outlet
surfaces ("outlet.stl");
includedAngle 150;
subsetFeatures
openEdges yes;
And finally, snappyHexMesh :
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
inlet_air.stl {type triSurfaceMesh; name inlet_air;}
inlet_eau.stl {type triSurfaceMesh; name inlet_eau;}
outlet.stl {type triSurfaceMesh; name outlet;}
wall.stl {type triSurfaceMesh; name wall;}
// Analytical shape; cylinder, sphere
refinementBox {type searchableBox; min (-1.0 -0.7 0.0); max ( 8.0 0.7 2.5);}
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// If local number of cells is >= maxLocalCells on any processor
// switches from from refinement followed by balancing
// (current method) to (weighted) balancing before refinement.
maxLocalCells 100000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 200000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 0;
// Allow a certain level of imbalance during refining
// (since balancing is quite expensive)
// Expressed as fraction of perfect balance (= overall number of cells /
// nProcs). 0=balance always.
maxLoadUnbalance 10;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/triSurface for now.
features
{file "inlet_air.eMesh"; level 2;}
{file "inlet_eau.eMesh"; level 2;}
{file "outlet.eMesh"; level 2;}
{file "wall.eMesh"; level 2;}
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
inlet_air {level (2 8);}
inlet_eau {level (2 8);}
wall {level (2 8);}
outlet {level (2 8);}
// Resolve sharp angles
resolveFeatureAngle 60;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
refinementBox
mode outside;
levels ((1E15 3));
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the locationInMesh is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
locationInMesh (0 0 15);
// Whether any faceZones (as specified in the refinementSurfaces)
// are only on the boundary of corresponding cellZones or also allow
// free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 3;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 4.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
// Feature snapping
//- Number of feature edge snapping iterations.
// Leave out altogether to disable.
nFeatureSnapIter 10;
//- Detect (geometric) features by sampling the surface
implicitFeatureSnap false;
//- Use castellatedMeshControls::features
explicitFeatureSnap true;
//- Detect features between multiple surfaces
// (only for explicitFeatureSnap, default = false)
multiRegionFeatureSnap true;
// Settings for the layer addition.
addLayersControls
// Are the thickness parameters below relative to the undistorted
// size of the refined cell outside layer (true) or absolute sizes (false).
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
"flange.*"
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.0;
// Wanted thickness of final added cell layer. If multiple layers
// is the thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
// See relativeSizes parameter.
finalLayerThickness 0.3;
// Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.1;
// If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
nGrow 0;
// Advanced settings
// When not to extrude surface. 0 is flat surface, 90 is when two faces
// are perpendicular
featureAngle 30;
// Maximum number of snapping relaxation iterations. Should stop
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 2;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
minMedianAxisAngle 90;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations
nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
//- Max skewness allowed. Set to <0 to disable.
maxBoundarySkewness 20;
maxInternalSkewness 4;
//- Max concaveness allowed. Is angle (in degrees) below which concavity
// is allowed. 0 is straight face, <0 would be convex face.
// Set to 180 to disable.
maxConcave 80;
//- Minimum projected area v.s. actual area. Set to -1 to disable.
minFlatness 0.5;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
// Set to a sensible fraction of the smallest cell volume expected.
// Set to very negative number (e.g. -1E30) to disable.
minVol 1e-13;
minTetQuality 1e-30;
//- Minimum face area. Set to <0 to disable.
minArea -1;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
// and face centre triangles normal
minTwist 0.02;
//- Minimum normalised cell determinant
// 1 = hex, <= 0 = folded or flattened illegal cell
minDeterminant 0.001;
//- minFaceWeight (0 -> 0.5)
minFaceWeight 0.02;
//- minVolRatio (0 -> 1)
minVolRatio 0.01;
// must be >0 for Fluent compatibility
minTriangleTwist -1;
// Advanced
//- Number of error distribution iterations
nSmoothScale 4;
//- Amount to scale back displacement at error points
errorReduction 0.75;
// Advanced
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-7;
And here is the boundary file in the polymesh folder :
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
6
front
type symmetryPlane;
inGroups List<word> 1(symmetryPlane);
nFaces 8192;
startFace 1552384;
back
type symmetryPlane;
nFaces 8192;
startFace 1560576;
inlet
type patch;
nFaces 8192;
startFace 1568768;
outlet
type patch;
nFaces 8192;
startFace 1576960;
lowerWall
type wall;
inGroups List<word> 1(wall);
nFaces 4096;
startFace 1585152;
upperWall
type symmetryPlane;
nFaces 4096;
startFace 1589248;
As you can see, it only has the boundary that was set up by default in the blockMeshDict. Why isn't there every other boundary (inlet_air, outlet, wall and inlet_eau ?)
Thank you
Haroun is offline   Reply With Quote
Old   March 2, 2025, 02:42
Abdul Adhl Azeez
abduladhlazeez is on a distinguished road
Did you get a solution to this? My snappyHexMesh is behaving in the same way
abduladhlazeez is offline   Reply With Quote
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 07:47
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
