enthusiast |
May 31, 2022 09:31 |
Water level is raising as simulation progresses
2 Attachment(s)
I am conducting two-phase flow simulations in a separator with 3 inlets and 2 outlets using twoPhaseEulerFoam in OF version 8.
The inlet velocity BC is specified at 2 inlets and pressure outlet BC is specified at the 2 outlets.
Initially, half of the separator volume is filled with water using setFieldDict.
I am expecting the water level to remain constant but strangely the water level increases.
I was expecting flow in = flow out, the velocity vector at the water outlet is not correctly calculating the water velocity at the outlet.
I have attached my BC for U, p_rgh, alpha fields below.
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
inlet1
type fixedValue;
value uniform 0.698;
inlet2
type fixedValue;
inlet3
type fixedValue;
walls
type zeroGradient;
baffle1
type zeroGradient;
baffle2
type zeroGradient;
baffle3
type zeroGradient;
outlet1
type inletOutlet;
phi phi.water;
inletValue uniform 1;
value uniform 1;
outlet2
type inletOutlet;
phi phi.water;
inletValue uniform 0;
value uniform 0;
FoamFile
version 2.0;
format ascii;
location "0";
object alpha.oxygen;
internalField uniform 1;
boundaryField
inlet1
type fixedValue;
value uniform 0.302;
inlet2
type fixedValue;
inlet3
type fixedValue;
walls
type zeroGradient;
baffle1
type zeroGradient;
baffle2
type zeroGradient;
baffle3
type zeroGradient;
outlet1
type inletOutlet;
phi phi.oxygen;
value uniform 0;
outlet2
type inletOutlet;
phi phi.oxygen;
value uniform 1;
FoamFile
version 2.0;
format ascii;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 4.01325e5;
boundaryField
inlet1
type fixedFluxPressure;
value $internalField;
inlet2
inlet3
walls
baffle1
baffle2
baffle3
outlet1 //water outlet
type prghPressure;
p $internalField;
outlet2 //oxygen outlet
type fixedValue;
FoamFile
version 2.0;
format binary;
class volVectorField;
object U.water;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet1
type fixedValue;
value uniform (0 0 3.83);
inlet2
type fixedValue;
value uniform (0 0 -3.83);
inlet3
type fixedValue;
walls
type noSlip;
baffle1
type noSlip;
baffle2
type noSlip;
baffle3
type noSlip;
outlet1
type pressureInletOutletVelocity;
phi phi.water;
outlet2
phi phi.water;
FoamFile
version 2.0;
format binary;
object U.oxygen;
boundaryField
inlet1
type fixedValue;
value uniform (0 0 1.66);
inlet2
type fixedValue;
value uniform (0 0 -1.66);
inlet3
type fixedValue;
walls
type fixedValue;
value uniform (0 0 0);
baffle1
type fixedValue;
baffle2
type fixedValue;
baffle3
type fixedValue;
outlet1
phi phi.oxygen;
outlet2
phi phi.oxygen;
I have also attached the water level at 0 sec and 20 sec simulation time.
Attachment 90079
Attachment 90080
Thank you.
