Error in compilation of geometricVoF
Old   June 20, 2022, 10:46
Default Error in compilation of geometricVoF
Muhd Jamil Al Hakim
Jamill1283 is on a distinguished road
Send a message via Yahoo to Jamill1283 Send a message via Skype™ to Jamill1283
Hi Everyone,
I am a new Open-FOAM user, and quite new to C++ programming with basic understanding. I am trying to manually compile geometricVoF as required by atomizationFoam solver (by Martin Heinrich) using OpenFOAM v1912. However, the following error appears that cause the compilation failed.
reconstructionSchemes/plicSchemes/gradAlpha/gradAlpha.C:98:2: error: uninitialized reference member in ‘class Foam::zoneDistribute&’ [-fpermissive]
98 | Foam::reconstruction::gradAlpha::gradAlpha
The code for gradAlpha.c is as below
 #include "gradAlpha.H"
 #include "fvc.H"
 #include "leastSquareGrad.H"
 #include "addToRunTimeSelectionTable.H"
 #include "profiling.H"
 // * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
 namespace Foam
 namespace reconstruction
     defineTypeNameAndDebug(gradAlpha, 0);
     addToRunTimeSelectionTable(reconstructionSchemes, gradAlpha, components);
 // * * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * //
 void Foam::reconstruction::gradAlpha::gradSurf(const volScalarField& phi)
     addProfilingInFunction(geometricVoF);
     leastSquareGrad<scalar> lsGrad("polyDegree1",mesh_.geometricD());
     zoneDistribute& exchangeFields = zoneDistribute::New(mesh_);
     exchangeFields.setUpCommforZone(interfaceCell_,true);
     Map<vector> mapCC
         exchangeFields.getDatafromOtherProc(interfaceCell_, mesh_.C())
     Map<scalar> mapPhi
         exchangeFields.getDatafromOtherProc(interfaceCell_, phi)
     DynamicField<vector> cellCentre(100);
     DynamicField<scalar> phiValues(100);
     const labelListList& stencil = exchangeFields.getStencil();
     forAll(interfaceLabels_, i)
         const label celli = interfaceLabels_[i];
         cellCentre.clear();
         phiValues.clear();
         for (const label gblIdx : stencil[celli])
             cellCentre.append
                 exchangeFields.getValue(mesh_.C(), mapCC, gblIdx)
             phiValues.append
                 exchangeFields.getValue(phi, mapPhi, gblIdx)
         cellCentre -= mesh_.C()[celli];
         interfaceNormal_[i] = lsGrad.grad(cellCentre, phiValues);
 // * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
     volScalarField& alpha1,
     const surfaceScalarField& phi,
     const volVectorField& U,
     const dictionary& dict
         typeName,
         alpha1,
         phi,
         U,
         dict
     mesh_(alpha1.mesh()),
     interfaceNormal_(fvc::grad(alpha1)),
     isoFaceTol_(modelDict().getOrDefault<scalar>("isoFaceTol", 1e-8)),
     surfCellTol_(modelDict().getOrDefault<scalar>("surfCellTol", 1e-8)),
     sIterPLIC_(mesh_,surfCellTol_)
     reconstruct();
 // * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * * //
 void Foam::reconstruction::gradAlpha::reconstruct(bool forceUpdate)
     const bool uptodate = alreadyReconstructed(forceUpdate);
     if (uptodate && !forceUpdate)
         return;
     if (mesh_.topoChanging())
         // Introduced resizing to cope with changing meshes
         if (interfaceCell_.size() != mesh_.nCells())
             interfaceCell_.resize(mesh_.nCells());
     interfaceCell_ = false;
     interfaceLabels_.clear();
     forAll(alpha1_, celli)
         if (sIterPLIC_.isASurfaceCell(alpha1_[celli]))
             interfaceCell_[celli] = true; // is set to false earlier
             interfaceLabels_.append(celli);
     interfaceNormal_.resize(interfaceLabels_.size());
     centre_ = dimensionedVector("centre", dimLength, Zero);
     normal_ = dimensionedVector("normal", dimArea, Zero);
     gradSurf(alpha1_);
         if (mag(interfaceNormal_[i]) == 0)
             continue;
         sIterPLIC_.vofCutCell
             celli,
             alpha1_[celli],
             isoFaceTol_,
             100,
             interfaceNormal_[i]
         if (sIterPLIC_.cellStatus() == 0)
             normal_[celli] = sIterPLIC_.surfaceArea();
             centre_[celli] = sIterPLIC_.surfaceCentre();
             if (mag(normal_[celli]) == 0)
                 normal_[celli] = Zero;
                 centre_[celli] = Zero;
         else
 void Foam::reconstruction::gradAlpha::mapAlphaField() const
     // Without this line, we seem to get a race condition
     mesh_.C();
     cutCellPLIC cutCell(mesh_);
     forAll(normal_, celli)
         if (mag(normal_[celli]) != 0)
             vector n = normal_[celli]/mag(normal_[celli]);
             scalar cutValue = (centre_[celli] - mesh_.C()[celli]) & (n);
             cutCell.calcSubCell
                 celli,
                 cutValue,
                 n
             alpha1_[celli] = cutCell.VolumeOfFluid();
     alpha1_.correctBoundaryConditions();
     alpha1_.oldTime () = alpha1_;
     alpha1_.oldTime().correctBoundaryConditions();
I attached the log file as a reference
wmake_manual_geometricVoF1.txt
The related file also attached as below
zoneDistribute.H
zoneDistributeI.H
If you need something else, please just ask me. Many thanks
Jamill1283 is offline   Reply With Quote
Old   June 21, 2022, 05:52
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
The short answer (looking at your log) - get a newer OpenFOAM version such as OpenFOAM-v2112 or even wait a few days and grab OpenFOAM-v2206. The version you are using is already more than 2.5 years old and the compilation issues with SLList have long been fixed.
EDIT: you should also know that zoneDistribute is also part of the standard OpenFOAM in newer versions.
olesen is offline   Reply With Quote
[foam-extend.org] foam-extend-3.2 compilation on windows kirmaks OpenFOAM Installation 9 December 10, 2025 05:08
[waves2Foam] Problems with the compilation of the third party dependencies chia87 OpenFOAM Community Contributions 7 May 20, 2017 07:04
Compilation error for OpenFOAM-ext on Ubantu 10.04 32 bit Sargam05 OpenFOAM Installation 13 March 22, 2014 06:21
Compilation Error (V 1.7.1; Icc 12.1.0, OpenMPI 1.4.3) floydfan OpenFOAM Installation 7 December 20, 2011 06:56
Compilation Error.... Arnab Siemens 4 September 12, 2004 16:54
