[Sponsors] | |||||
Olabode Ajenifujah
Rep Power: 5 ![]() |
Hello, I got this error message while working with openfoam, Although I have looked at the constant file for the possible of the error, but I could not find it. Do I need to change something in the dictionaryTemplates.C
[0] --> FOAM FATAL IO ERROR: (openfoam-2112) [0] Entry 'type' not found in dictionary "/OpenFOAM/run/test/constant/phaseProperties.surfaceTension" [0] [0] [0] file: constant/phaseProperties.surfaceTension at line 132 to 153. [0] [0] From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType: ption, bool) const [with T = Foam::word][0] in file /home/OpenFOAM/OpenFOAM-v2112/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [1] [1] [1] --> FOAM FATAL IO ERROR: (openfoam-2112) [1] Entry 'type' not found in dictionary "stream.surfaceTension" [1] [1] [1] file: stream.surfaceTension at line 0. [1] [1] From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType: ption, bool) const [with T = Foam::word][1] in file /home/OpenFOAM/OpenFOAM-v2112/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322. [1] FOAM parallel run exiting [1] [2] [2] [2] --> FOAM FATAL IO ERROR: (openfoam-2112) [2] Entry 'type' not found in dictionary "stream.surfaceTension" [2] [2] [2] file: stream.surfaceTension at line 0. [2] [2] From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType: ption, bool) const [with T = Foam::word][2] in file /home/OpenFOAM/OpenFOAM-v2112/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322. [2] FOAM parallel run exiting |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 05:53 |
| [swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
| Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
| How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 06:07 |
| CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
