decomposePar changes fixedGradient BC
Old   July 4, 2022, 01:21
Default decomposePar changes fixedGradient BC
chen
vb276 is on a distinguished road
I am trying to simulate a pipe flow ,and boundary condition for temperature at outer is
fixedGradient
gradient uniform -100,
but after decomposePar ,the BC change to
fixedGradient
gradient nonuniform List<scalar>
before decomposePar
[boundaryField
    inter
        type            zeroGradient;
    outer
        type            fixedGradient;
        gradient           uniform -100;
    inlet1
        type            cyclic;
    outlet1
        type            cyclic;
    left
        type            cyclic;
    right
        type            cyclic;
after decomposePar[boundaryField
    inter
        type            zeroGradient;
    outer
        type            fixedGradient;
        gradient        nonuniform List<scalar> 0();
    inlet1
        type            cyclic;
    outlet1
        type            cyclic;
    left
        type            cyclic;
    right
        type            cyclic;
    procBoundary0to1
        type            processor;
        value           uniform 300;
    procBoundary0to2
        type            processor;
        value           uniform 300;
is there anyone who know the reason?
vb276 is offline   Reply With Quote
Old   August 28, 2022, 11:08
Joachim Herb
jherb is on a distinguished road
nonuniform List<scalar> 0(); means that there are 0 faces of this patch calculated on the processor you looked at. If you look at this field file in the other processor directories you will find one/more which contain the correct value, because on this/these processor(s) the boundary is really used.
jherb is offline   Reply With Quote
fixedgradient parallel
Threaded decomposepar sqek OpenFOAM Pre-Processing 0 October 8, 2021 14:31
fixedGradient BC type with the channelOodles solver Bedotto OpenFOAM Running, Solving & CFD 5 April 15, 2019 10:49
decomposePar problem: Cell 0contains face labels out of range (Again)) limonegiallo OpenFOAM Pre-Processing 4 August 28, 2017 06:18
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 09:57
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 06:27
