[Sponsors] | |||||
How to dinamically update rpm in propellerinfo based on 6dof computations |
Eduardo Firvida
Rep Power: 17 ![]() |
Hi, I'm testing the new propellerinfo postprocessing tool, in which I need to supply the propeller rpm. For the cases where I use a fixed rotation giving the angular velocity, there is no problem. But now I'm using 6Dof for computing the propeller rotation, in that case, how can I change the rpm in the config file based on the computation?
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to update supply temp on one patch based on the measure temp on another patch? | er_ijaz | OpenFOAM Programming & Development | 2 | July 10, 2020 12:00 |
| [ICEM] Cannot update new.3dm file in ICEM based on rpl file | jimmy871013 | ANSYS Meshing & Geometry | 3 | June 20, 2017 12:02 |
| Cannot update new.3dm file in ICEM based on rpl file | jimmy871013 | Mesh Generation & Pre-Processing | 1 | June 20, 2017 03:21 |
| To determine the RPM of the fan/turbine based on flow | ritvik | FLUENT | 0 | February 16, 2012 02:23 |
| OpenFoam 1.6-ext - RPM build errors | preibie | OpenFOAM | 12 | September 8, 2011 04:12 |
