boundary Cyclic 3D
Old   July 20, 2022, 10:35
Default boundary Cyclic 3D
Boucetta Lahcene
B6_lacen is on a distinguished road
Hello everyone
I want to make a 3D simulation of airfoil, I made the gonometry with Isis-cfd.
I changed in boundary the name of patch in cyclic and also in file 0, but it displays me an error.
Do you have a tip to unblock this bug please. Thanks a lot
This is the error:
[100] --> FOAM FATAL ERROR: (openfoam-2106)
[100] face 0 area does not match neighbour by 192.6987% -- possible face ordering problem.
patchrocBoundary100to15throughZmax my area:5.721409e-07 neighbour area:1.063766e-08 matching tolera
nce:9.255939e-11
Mesh face:252543 vertices:4((0.3441662 0.1384074 4) (0.3460498 0.138489 4) (0.3460351 0.1387911 4) (0
.3441423 0.1387097 4))
If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patc
h dictionary in the boundary file.
Rerun with processor debug flag set for more informatio
CheckMesh:
| \\ / O peration | Version: 2112 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _d44c8318-20220111 OPENFOAM=2112 version=2112
Arch : "LSB;label=32;scalar=64"
Exec : checkMesh
Date : Jul 20 2022
Time : 15:23:03
Host : cfduser-VM
PID : 12951
I/O : uncollated
Case : /home/cfd-user/Downloads/Cluster/3D_SST
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Time = 0
Mesh stats
faces: 37055539
internal faces: 36637101
cells: 12244720
faces per cell: 6.01832
boundary patches: 8
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 12031680
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 213040
Breakdown of polyhedra by number of faces:
faces number of cells
7 201760
8 11280
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
Zmin 153059 155163 ok (non-closed singly connected)
Zmax 153059 155163 ok (non-closed singly connected)
Intrados 46960 47628 ok (non-closed singly connected)
Extrados 52560 53298 ok (non-closed singly connected)
Inlet 3200 3321 ok (non-closed singly connected)
Ymax 3200 3321 ok (non-closed singly connected)
Outlet 3200 3321 ok (non-closed singly connected)
Ymin 3200 3321 ok (non-closed singly connected)
Checking faceZone topology for multiply connected surfaces...
No faceZones found.
Checking basic cellZone addressing...
No cellZones found.
Checking geometry...
Overall domain bounding box (-40 -40 0) (40 40 4)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (1.827013e-17 -2.633984e-17 8.461201e-13) OK.
B6_lacen is offline   Reply With Quote
Old   August 10, 2022, 06:59
hewei is on a distinguished road
Originally Posted by B6_lacen View Post
Hello everyone
This is the error:
nce:9.255939e-11
Attachment 90836
CheckMesh:
Exec : checkMesh
Date : Jul 20 2022
Time : 15:23:03
Host : cfduser-VM
PID : 12951
I/O : uncollated
nProcs : 1
Create time
Time = 0
Mesh stats
faces: 37055539
cells: 12244720
boundary patches: 8
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 12031680
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 213040
7 201760
8 11280
Point usage OK.
Face vertices OK.
No faceZones found.
No cellZones found.
have you checked your result, is it periodic? thanks
hewei is offline   Reply With Quote
Cyclic boundary condition in foam-extend 4.0 rellumeister OpenFOAM Pre-Processing 2 March 3, 2020 09:03
time step continuity error increases with time_SRFSimplefoam mostafa kamal OpenFOAM Running, Solving & CFD 7 October 2, 2019 03:00
Possible createPatch/createBaffles bug? simpomann OpenFOAM Bugs 2 July 15, 2014 08:07
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
