August 14, 2022, 14:01 |
How to define blocks in blockmesh
Rep Power: 4 |
I am trying to make a big block out of nine smaller blocks to be able to refine them separately afterwards. I defined the vertices and the blocks, as you can see below. I tried to define it in a few ways, but none of them worked. Every time when I run the blockMesh command, there are some mistakes. Could someone please help me find out what's wrong? The blockMeshDict file and a picture which shows the mistake is included. Thanks in advance Last edited by Thiago800; August 17, 2022 at 10:35. |
August 15, 2022, 07:25 |
Does this https://github.com/damogranlabs/classy_blocks help?
August 16, 2022, 09:56 |
Rep Power: 4 |
Hi dlahaye, thanks for your response. I don't have any experience with python therefor unfortunately it's not helpful. Is there maybe a simpler tool or way to do that?
blockmesh |
HELP----Surface Reaction UDF | Ashi | Fluent UDF and Scheme Programming | 1 | May 19, 2020 21:13 |
[blockMesh] blockMesh problem with wedge blocks | gned | OpenFOAM Meshing & Mesh Conversion | 0 | September 14, 2016 05:49 |
[blockMesh] How to define symmetric graded mesh without using multiple blocks | sahmed | OpenFOAM Meshing & Mesh Conversion | 3 | August 18, 2016 03:33 |
An odd ERROR | mdakbari | Fluent UDF and Scheme Programming | 7 | April 4, 2016 04:30 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
