funkySetFields and the time component
Old   September 14, 2022, 00:58
Default funkySetFields and the time component
Josh McCraney
joshmccraney is on a distinguished road
Can anyone explain how the "funkySetFields time -XX " component of funkySetFields works? Whenever I execute "funkySetFields time -0.2" it initializes the field at 0. What's happening here?
Evidently the solution *SO FAR* is to run your sim up to the desired time, then you must execute "reconstructPar", then you must execute "funkySetFields time -0.2", and then view the mesh in paraFoam via reconstructed mesh. You should see the simulation has changed the field you've specified. HOWEVER, upon running the simulation again in parallel, it's as if it has no memory that we changed fields, and it continues running as normal.
FINAL EDIT: IT WORKS! You must delete all processor* and THEN decomposePar again. You'll lose all memory of times 0-->0.2, but it'll work from 0.2 on out!
joshmccraney is offline   Reply With Quote
Old   October 18, 2022, 22:28
Josh McCraney
To reiterate:
1) run sim to desired time. Then reconstructPar (if in parallel).
2) rm -r processor* to clear all processors
3) run funkSetFields with the desired time (must have folder corresponding to that time)
4) decomposePar and execute running
If done correctly, I can confirm the field will be set to what you specify in the funkySetFields dict.
Make sure controlDict runs from latest time.
