Creation of cyclic baffles fails with OpenFOAM 10
I am trying to migrate my models from OpenFOAM 8 to OpenFOAM 10. I noticed the following commit which required changes to the input syntax for baffle creation.
Previously the baffle was defined using e.g.: Code:
internalFacesOnly true; Code:
internalFacesOnly true; Quote:
When using "fields false" in createBafflesDict the operation succeeds but later decomposePar fails because obviously the fields are not defined for the baffle sides. It would be great if anybody could shed light onto this. I am trying to figure out the problem since a few days now without success. Apparently it is not a bug because my issue was closed as a user support request. Unfortunately I fail to see what I am doing wrong. An online search for the error message also did not yield anything useful and the only issue I found here in the forum is this which is unresolve. also it is related to extrudeToRegion and not createBaffles. There is a question related to this. I am creating the cyclic baffle because I want to evaluate the pressure at a faceZone. This does not work (or at least I found no way to do so directly) thus I created the cyclic baffle to evaluate the pressure like for a boundary patch. Code:
facePressure_inte_eval_baffle |
Not verified this completely but it looks like since recent versions of OpenFOAM it is possible to evaluate scalars at a surface even without interpolation.
pressure_eval |
