Turn off the combustion for buoyantReactingFoam;
Old   October 22, 2022, 08:39
Default Turn off the combustion for buoyantReactingFoam;
Rongqi Peng
Rongqi P is on a distinguished road
Dear Foamers,
I wanted to simulate the case that CH4 leakage in the air on OpenFOAM 9, but I didn't want to involve combustion and chemical reactions, so I entered "active off" in "combustionProperties" to try to turn off combustion, but the calculation still resulted in the combustion reaction.
I would like to ask for your help.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 9
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
location "constant";
object combustionProperties;
combustionModel infinitelyFastChemistry;
active off;
infinitelyFastChemistryCoeffs
semiImplicit no;
C 5.0;
Rongqi P is offline   Reply With Quote
Old   October 23, 2022, 14:06
Domenico Lahaye
dlahaye is on a distinguished road
The Sandia-D tutorial switches combustion off in initial stage of computations. Have a look at the Allrun script.
dlahaye is offline   Reply With Quote
Old   October 24, 2022, 06:00
Rongqi Peng
Thanks for your patience!
For the Sandia-D case, I have tried to turn the combustion off and it's work according to the post (How to switch off combustion and reaction in reactingFoam).
Sandia-D case is based on reactingFoam, but my case is based on buoyantReactingFoam. Their difference is that the buoyantReactingFoam case does not have the file "chemistryProperties" in the "constant" folder. So I don't know how to turn off the chemical reaction. Because if I just turn off the combustion and reaction in the "combustionProperties" and "reaction" respective, it will still report an error.
The error is as follows:
--> FOAM FATAL ERROR:
lookup of combustionProperties from objectRegistry region0 successful
but it is not a combustionModel, it is a none
From function const Type& Foam:bjectRegistry::lookupObject(const Foam::word&) const [with Type = Foam::combustionModels::singleStepCombustion]
in file /home/prq/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 178.
FOAM aborting
Old   October 24, 2022, 07:11
Domenico Lahaye
what if you create a constant/chemistryProperties file?
openfoam 9;
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 04:10
Partially Premixed Combustion - Direct Fired Boiler oknus FLUENT 0 April 10, 2012 10:52
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 06:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 18:40
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 18:23
