alpie77 |
May 5, 2023 12:29 |
setFieldsDict - Ellipse
Hello everyone,
I am working on an Openfoam assignment at my university. For this assignment, I need to use setFieldsDict and define an ellipsoid volume or region ( It is 3D) and set different values for inside and outside of the ellipsoid region. But I could not find any documentation on defining an ellipsoid region in setFields.
I could manage to do it with funkySetFields which is below.
In this funkysetfields an ellipsoid is defined and inside the ellipsoid thermal diffusivity for sand is valid, outside of this ellipsoid diffusivity of aluminum is valid.
FoamFile
version 2.0;
format ascii;
root "";
case "defective cooler";
instance "system";
local "";
class dictionary;
object funkySetFieldsDict;
expressions
aAluminum
field a;
expression "8.418e-5";
condition "sqr((pos().x-0.003))/(sqr(0.015))+sqr((pos().y-0.0045))/(sqr(0.0007))+sqr((pos().z-0.003))/(sqr(0.001))>1";
// This equation describes the inside or outside of an ellipsoid.
aSand
field a;
expression "1-12e-6";
condition "sqr((pos().x-0.003))/(sqr(0.015))+sqr((pos().y-0.0045))/(sqr(0.0007))+sqr((pos().z-0.003))/(sqr(0.001))<1";
Question :
I need to do the same thing with OpenFOAM V10, setFieldsDict.
How can I do the same thing, in setFieldsDict?
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 10
\\/ M anipulation |
FoamFile
format ascii;
class dictionary;
object setFieldsDict;
defaultFieldValues
volScalarFieldValue a 8.418e-5
regions
// Setting values inside a sphere
sphereToCell
centre (0.015 0.0045 0.003);
radius (0.003 0.007 0.001); // I tried to give 3 radiui assuming in 3D, but this did not work of course :)//
fieldValues
volScalarFieldValue a 1.12e-6
Thanks for your help and effort.
