How to handle the interface between rotor and stator?
Like Tree1Likes
  • 1 Post By MarcoC501
Old   May 12, 2023, 12:49
Default How to handle the interface between rotor and stator?
MC
MarcoC501 is on a distinguished road
Dear all,
I have recently used OpenFOAM (v2012) for simulating the Rotor37, and the results with rhoSimpleFoam are similar to those from the literature and from CFX (ANSYS).
I am now trying to add up the stator and I would like to have some advice on how I should handle the rotor-stator interface.
From what I have seen there's no available package for the mixing-plane option (for steady state RANS simulations), do you confirm that?
For this reason I thought about using rhoPimpleDyMFoam, so directly go unsteady and introduce a moving mesh. The main problem here is related to the matching of the interface: should the two patches of interface between rotor and stator (set with cyclicAMI) match perfectly? For instance, in CFX the pitch ratio can be in the ratio 0.6-1.5, but is this still valid for OpenFOAM?
Moreover, feel free to suggest any example of simulations of this type from the literature (I could not find much related to the OpenFOAM I am using). I would really appreciate that.
Thanks a lot
Best,
Marco
Rahmat1 likes this.
MarcoC501 is offline   Reply With Quote
Old   May 17, 2023, 05:42
MC
Dear all,
I have figured it out.
I installed foam-extend 5.0 and here there are some routines capable of dealing with the interface problem.
I have been trying both mixingPlaneand ggiinterface, using steadyCompressibleMRFFoam and steadyUniversalMRFFoam.
Is rhoSimpleFoam supported for these two routines?
That's because the convergence is not so good with the PISO algorithm used in the tutorial (e.g. pressure residuals do not go down), at the limit of divergence, and I do not know if that's a problem of solver or BCs.
The stage is transonic, do you maybe have suggestions on what solver to use for foam-extend?
I really appreciate your help and support!
Old   May 17, 2023, 06:57
Rahmat
Rahmat1 is on a distinguished road
Marco,
I did model an axial fan installed in a wind tunnel using simplefoam and results were far as expected. Pressure across the fan was negative instead of a gain. Is it possible to share your model? Thanks.
Rahmat1 is offline   Reply With Quote
Old   May 17, 2023, 07:06
MC
Which version of OpenFOAM are you using?
There should be some tutorials on that in the $FOAM_tutorials folder.
May be related to your model?
For me, it is PIMPLE algorithm (in steadyCompressibleMRFFoam) is diverging. I also have looking at the BCs, they are the same as the ones I set when using rhoSimpleFoam (with slight modifications)...
