I really have no idea how should I rewrite csv file for U inlet
Old   June 12, 2023, 06:58
Default I really have no idea how should I rewrite csv file for U inlet
Březňák
breznak is on a distinguished road
I have a given velocity profile in csv file. The file looks like this:
X, Y, Z, Ux, Uy, Uz ,
-1.95E-02,-1.70E-02,4.08E-01,0.00E+00,0.00E+00,0.00E+00,
-1.94E-02,-1.70E-02,4.08E-01,0.00E+00,0.00E+00,0.00E+00,
-1.94E-02,-1.69E-02,4.08E-01,-1.76E-03,-1.57E-03,4.35E-01,
-1.95E-02,-1.69E-02,4.08E-01,0.00E+00,0.00E+00,0.00E+00,
-1.94E-02,-1.68E-02,4.08E-01,-2.13E-03,-6.79E-04,5.45E-01,
and so on
It means there are Ux Uy Uz values for every each coordinates.
And my ../0/U looks like this:
inlet
    type         uniformFixedValue;
    uniformValue
        type             tableFile;
        format           csv;
        nHeaderLine      4;              // number of header lines
        refColumn        0;              // time column index
        componentColumns (1);            // data column index
        separator        ",";            // optional (defaults to ",")
        mergeSeparators  no;             // merge multiple separators
        file             "U_inlet.csv";
How should I rewrite csv file? My simulation is steady so I am using simpleFoam so there cannot be time values...
breznak is offline   Reply With Quote
Old   June 15, 2023, 02:47
Vinzenz Götz
Vinzmann is on a distinguished road
Why do you use a csv for your velocity BC if your simulation is steady state?
You should consider using a transient solver or just use the last value for U for your simulation.
Vinzmann is offline   Reply With Quote
Custom Thermophysical Properties wsmith02 OpenFOAM 4 June 1, 2023 14:30
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
