Temperature gradient BC mismatchs with wallHeatFlux computation |
Nikos
Rep Power: 14 ![]() |
I use the chtMultiRegionFoam (openFoam v2012) to solve heat transfer between fluid and solid regions.
I have frozen the flow and at one boundary of the solid region (which is NOT in contact with the fluid), I impose a fixedGradient BC for the Temperature as follows: Code:
Geom4_2f { type fixedGradient; gradient uniform 20; } q = gradT/Ksolid = 20/117 = 0.17 W/m2 where Ksolid = 117 W/(mK) and gradT = 20 K/m (according the to the fixedGradient BC) Surprisingly enough, when I use the wallHeatFlux tool I get (for the same boundary) 2340 W/m2 ! The later can be also verified by the (large) increase of the temperature at the results. What is going on there? Are the fixedGradient units wrong? Any ideas? |
Display Modes | |
pisoFOAM (LES) - internal pipe flow - convergence | gu1 | OpenFOAM Running, Solving & CFD | 0 | January 11, 2018 16:39 |
temperature gradient for use in surface monitor | Catherine | FLUENT | 1 | August 24, 2012 09:10 |
Temperature Gradient at Wall | sven | OpenFOAM | 7 | November 1, 2010 17:25 |
Averaging 2D Wall Temperature Gradient | deji | OpenFOAM | 2 | July 23, 2010 15:06 |
Cyclic condition for temperature gradient | David_010 | OpenFOAM | 0 | May 23, 2010 11:55 |
