createbaffles with internalfaces=true gives a floating point error... |
Jacques
Rep Power: 8 ![]() |
I am trying to make a test case for a very very simple problem : i have an internal surface in a 3D mesh, exported as a wall. I want to convert this surface into a baffle and the use fan BC. it fails... badly.
So the setup : a box (wall names : sides) and a disk inside it (wall name ventilfan). fluent3DMeshtoFoam or whatever works, and creates the follwing boundary file : Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2212 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 2 ( ventilfan { type wall; inGroups 1(wall); nFaces 2966; startFace 651850; } sides { type wall; inGroups 1(wall); nFaces 8478; startFace 654816; } ) // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( // Generate faceZones for the createBaffles step // a) Generate a faceSet from a patch // b) Generate a faceZoneSet from the faceSet // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ // a) Create faceSet using patch interfaceInner { name interface1FaceSet; type faceSet; action new; source patchToFace; sourceInfo { patch ventilfan; } } // b) Create faceZoneSet using face set { name interface1FaceZone; type faceZoneSet; action new; source setToFaceZone; sourceInfo { faceSet interface1FaceSet; } } ); Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Overriding OptimisationSwitches according to controlDict fileHandler (unregistered) Overriding fileHandler to uncollated I/O : uncollated Create polyMesh for time = 0 Reading topoSetDict Time = 0 mesh not changed. Created faceSet interface1FaceSet Applying source patchToFace Adding all faces of patches (ventilfan) ... Found matching patch ventilfan with 2966 faces. faceSet interface1FaceSet now size 2966 Created faceZoneSet interface1FaceZone Applying source setToFaceZone Adding all faces from faceSet interface1FaceSet ... faceZoneSet interface1FaceZone now size 2966 End Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createBafflesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Whether to convert internal faces only (so leave boundary faces intact). // This is only relevant if your face selection type can pick up boundary // faces. internalFacesOnly false; // Baffles to create. baffles { // NOTE: cyclicAMI patches MUST BE defined PRIOR to their associted // blockage patches cyclicFaces1 { //- Use predefined faceZone to select faces and orientation. type faceZone; zoneName interface1FaceZone; patches { master { //- Master side patch name fan_half0; type cyclic; neighbourPatch fan_half1; } slave { //- Slave side patch name fan_half1; type cyclic; neighbourPatch fan_half0; } } } } Code:
/ * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Overriding OptimisationSwitches according to controlDict fileHandler (unregistered) Overriding fileHandler to uncollated I/O : uncollated Create mesh for time = 0 Reading baffle criteria from createBafflesDict Reading geometric fields Reading volScalarField: AIR GAZ T Ydefault alphat k nut p p_rgh Reading volVectorField: U Created zone cyclicFaces1 at index 2 with 2966 faces --> FOAM Warning : From void createFaces(bool, const Foam::fvMesh&, const Foam::faceZone&, const labelList&, const labelList&, Foam::polyTopoChange&, Foam::bitSet&, Foam::label&) in file createBaffles.C at line 402 Found boundary face (in patch ventilfan) in faceZone cyclicFaces1 to convert to baffle patches fan_half0/fan_half1 Set internalFacesOnly to true in the createBaffles control dictionary if you don't wish to convert boundary faces. Converted 2966 faces into boundary faces in patches 2(fan_half0 fan_half1) #0 Foam::error::printStack(Foam::Ostream&) in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #1 Foam::sigFpe::sigHandler(int) in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 ? in /lib64/libpthread.so.0 #3 Foam::cyclicPolyPatch::getCentresAndAnchors(Foam::PrimitivePatch<Foam::SubList<Foam::face>, Foam::Field<Foam::Vector<double> > const&> const&, Foam::PrimitivePatch<Foam::SubList<Foam::face>, Foam::Field<Foam::Vector<double> > const&> const&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<Foam::Vector<double> >&, Foam::Field<double>&) const in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #4 Foam::cyclicPolyPatch::order(Foam::PstreamBuffers&, Foam::PrimitivePatch<Foam::SubList<Foam::face>, Foam::Field<Foam::Vector<double> > const&> const&, Foam::List<int>&, Foam::List<int>&) const in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #5 Foam::polyTopoChange::reorderCoupledFaces(bool, Foam::polyBoundaryMesh const&, Foam::UList<int> const&, Foam::UList<int> const&, Foam::UList<int> const&, Foam::Field<Foam::Vector<double> > const&) in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libmeshTools.so #6 Foam::polyTopoChange::compactAndReorder(Foam::polyMesh const&, Foam::UList<int> const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::objectMap>&, Foam::List<Foam::Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libmeshTools.so #7 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, Foam::UList<int> const&, bool, bool, bool, bool) in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libmeshTools.so #8 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool, bool, bool) in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/lib/libmeshTools.so #9 ? in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/bin/createBaffles #10 __libc_start_main in /lib64/libc.so.6 #11 ? in /clust/softs/OpenFOAM/OpenFOAM-v2212/platforms/linux64GccDPInt32Opt/bin/createBaffles Exception en point flottant So i am sure I am doing something very wrong very wrongly as it is a very very simple test and should just work out of the blue, but i can't figure out what... looking forward to have the dumb face when I understand it by readin your answers ![]() [edit] I failed the title : it fails with internalfacesonly = false, which i need I think otherwise I will have a wall in my doimain and also the two cyclic faecs have 0 cells... [edit2] I tried with a full tetra mesh, or even a full hexcore, same issue... so not related to poly I think ? |
Display Modes | |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
long error when using make-install SU2_AD. | tomp1993 | SU2 Installation | 3 | March 17, 2018 06:25 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
