How to initialize k and epsilon in RAS simulation via OpenFOAM
Old   May 14, 2024, 12:18
Default How to initialize k and epsilon in RAS simulation via OpenFOAM
mo magd
mo___ is on a distinguished road
I hope everything is going well.
I'm attempting to initialize my internal field and the boundary values for k and epsilon in an RAS simulation via OpenFOAM, but I'm unsure of how to proceed.
I've reviewed the examples in the tutorial folder to try and figure it out, but the way k and epsilon were initialized in those 0 folders struck me as odd. The values for epsilon seemed a bit high, as did those for k.
If k and epsilon represent the turbulent kinetic energy and turbulent dissipation rate, respectively, and we use the following formula for initialization:
k=1.5(UI)2
and
ϵ=cμ(k^(1.5)/l)
where I is the turbulence intensity (which is assumed to be 0.05) and l is the turbulent length scale.
According to these equations, if the fluid is initially at rest, k and epsilon should both be zero in the internal field, right? So why do I observe non-zero values in these tutorial folders for every case? Additionally, the method by which k and epsilon were calculated does not align with the values I would expect from these formulas.
Could someone please help me understand where I might be making a mistake?
Thanks!
mo___ is offline   Reply With Quote
Old   June 18, 2024, 15:35
Engineer
nnprashant is on a distinguished road
Can you provide some details about the model and the values which you are mentioning about k and epsilon.
nnprashant is offline   Reply With Quote
Old   July 8, 2024, 22:20
whichthreads is on a distinguished road
The presence of boundary layers, shear flows, or other flow features may affect the optimal initial conditions.
whichthreads is offline   Reply With Quote
Openfoam, Laminar versus K epsilon versus kwSST bineet_aero Main CFD Forum 0 November 13, 2020 12:55
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
Question on transient simulation in OpenFOAM and FLUENT nicklj OpenFOAM Running, Solving & CFD 4 May 8, 2014 23:30
calculate epsilon from RANS k-Omega simulation CFD_Monkey OpenFOAM Post-Processing 1 June 27, 2013 11:55
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
