[Sponsors] | |||||
Engineer
Rep Power: 14 ![]() |
Hello Foamers,
I'm currently simulating a volute of an axial compressor using OpenFOAM. The boundary conditions involve a mass flow inlet and pressure outlet, with the flow being compressible air. At the inlet, the flow does not enter normally; instead, it enters the volute at a 45° angle (both radial and tangential). I'm attempting to validate OpenFOAM results against Fluent. So far, I've explored several inlet boundary conditions: flowRateInletVelocity: Specifies flow normal to the boundary. swirlFlowRateInletVelocity: Seems promising, but I'm unsure how to precisely define the inlet angle. cylindricalInletVelocity: Found it unstable as mass flow rate depends on given velocity components. swirlInletVelocity: Similar to cylindricalInletVelocity. I conducted a test simulation using swirlFlowRateInletVelocity, and the results matched those from Fluent. My concern now is understanding how the solver calculates the flow angle based on axis, origin, and RPM. Any insights or advice on defining the inlet angle correctly would be greatly appreciated. Best regards, Nagaraj |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ncrit for a glider Xfoil. How to use it. GPT4 answer | AlanMattanó | Main CFD Forum | 0 | April 10, 2023 13:16 |
| Pressure drop and Mass flow rate | jzyk1212 | STAR-CCM+ | 0 | February 1, 2021 14:31 |
| rhoSimpleFoam with specified mass flow rate at outlet | ishan_ae | OpenFOAM Running, Solving & CFD | 3 | September 1, 2020 02:11 |
| Mass flow rate history over solution step- rhoSimpleFoam | gian93 | OpenFOAM Post-Processing | 0 | December 8, 2019 11:20 |
| Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 19:11 |
