rhoCentralFoam failed lookup of phi
Old   July 31, 2024, 19:38
Default rhoCentralFoam failed lookup of phi
Ibrahim I
Ibrahim_I is on a distinguished road
Hello, I am trying to do a simulation of filter pulse jet cleaning. It's mostly transonic flow through certain orifices and I am using porousBafflePressure on the filter walls. I am getting an error when I try to start the simulation, see below.
Build  : _1d8f0d55f7-20231221 OPENFOAM=2312 version=v2312
Arch   : "LSB;label=32;scalar=64"
Exec   : rhoCentralFoam
Date   : Jul 31 2024
Time   : 23:27:55
Host   : Ibrahim-2.local
PID    : 9337
I/O    : uncollated
Case   : /Users/iqbib/Downloads/pulsejettest
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
--> FOAM FATAL ERROR: (openfoam-2312)
    failed lookup of phi (objectRegistry region0)
    available objects of type surfaceScalarField:
0()
    From const Type &Foam::objectRegistry::lookupObject(const word &, const bool) const [Type = Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>]
    in file /Volumes/OpenFOAM-v2312/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 628.
FOAM exiting
I get the same error when trying other solvers too such as sonicFoam. Please can you help me fix it.
Dropbox link to my case below if you want to check it
https://www.dropbox.com/scl/fo/fubpx...=m6j962w0&dl=0
Ibrahim_I is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 06:25
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
