Negative temperature problem
Old   August 5, 2024, 23:39
Default Negative temperature problem
Kim jeamin
mongya is on a distinguished road
Hi, I am trying to perform customized openfoam from hotRadiationRoom tutorial. But, after running buoyantSimpleFoam I got an error message which is
--> FOAM FATAL ERROR: (openfoam-2312 patch=240220)
Negative initial temperature T0: -38.723
And, what I set in T file is
outlet
type fixedValue;
value uniform 300;
wall
type zeroGradient;
wall1
type zeroGradient;
inlet1
type zeroGradient;
/*type calculated;
value $internalField;*/
inlet2
type zeroGradient;
/*type calculated;
airconditioner
type fixedValue;
value uniform 290;
contact_region-src
type empty;
contact_region-trg
type empty;
contact_region_2-src
type empty;
contact_region_2-trg
type empty;
contact_region_3-src
type empty;
contact_region_3-trg
type empty;
I dont't really know what is the problem with my custom case.
mongya is offline   Reply With Quote
Averaging over iterations for steady-state simulation CFD student Fluent UDF and Scheme Programming 8 September 22, 2022 04:39
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
rhoCentralFoam Negative initial temperature in simulation of gas jet into vacuum c_underwood OpenFOAM Running, Solving & CFD 1 November 19, 2020 15:45
sonicFoam forwardstep negative temperature problem. ecad OpenFOAM Running, Solving & CFD 2 January 8, 2018 19:31
Problem when adding temperature to interFoam houkensjtu OpenFOAM 4 November 5, 2012 03:35
