p and p_rgh in simple algorithm
Old   August 13, 2024, 10:32
Default p and p_rgh in simple algorithm
Kim jeamin
mongya is on a distinguished road
Hi, everyone.
I am new to openfoam and I am not sure the BCs that I set are right or not.
Should BCs in p_rgh file be the same as BCs in p file? Or Is it okay to consider them independently?
mongya is offline   Reply With Quote
Old   August 13, 2024, 11:13
Yann
Yann will become famous soon enoughYann will become famous soon enough
Hello Kim,
For solvers using p_rgh, your BCs have to be defined in p_rgh.
p BCs would be usually set to calculated.
In such situation, have a look to the tutorials corresponding to the solver you want to use to see how the BCs are defined.
Yann
Yann is online now   Reply With Quote
Old   August 13, 2024, 21:17
Kim jeamin
Originally Posted by Yann View Post
Hello Kim,
Yann
Dear Yann
Thank you for your reply. I set BCs as you advised. But, I am not sure if my BCs are valid. It seems there is not any problem during iterations. Does it mean they are valid?
My BCs in p and p_rgh file are as follows :
BCs in p file
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
/*  the tutorials :  floor
        type            calculated;
        value           $internalField;
    ceiling
        type            calculated;
    fixedWalls
        type            calculated;
	inlet1
		type            zeroGradient;
    inlet2
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    airconditioner
        type            zeroGradient;
    wall1
        type            zeroGradient;
BCs in p_rgh file
boundaryField
        type            fixedFluxPressure;
        rho             rhok;
        value           uniform 0;
    ceiling
        rho             rhok;
        value           uniform 0;
    fixedWalls
        rho             rhok;
        value           uniform 0;
	inlet1
		type            zeroGradient;
		rho             rhok;
    inlet2
        type            zeroGradient;
		rho             rhok;
    outlet
        type            fixedValue;
		rho             rhok;
        value           uniform 0;
    airconditioner
        type            zeroGradient;
		rho             rhok;
    wall1
        type            zeroGradient;
		rho             rhok;
Respectfully.
Old   August 15, 2024, 06:55
Yann
Hello Kim,
The fact your case is able to run does not necessarily mean your setup is physically correct (OpenFOAM will crash or throw an error only if something in your setup is preventing it to solve the equations)
I see you copied and commented some BCs coming from tutorials, but you didn't use these BCs on the actual patches you have in your case.
In p_rgh, your patches defined as zeroGradient should use fixedFluxPressure instead (as it is done in the tutorials) and in p your BCs should be defined as calculated.
Regards,
Yann
