Set outlet normal velocity or averaged mass flow
Old   August 22, 2024, 19:45
Default Set outlet normal velocity or averaged mass flow
Ibrahim I
Ibrahim_I is on a distinguished road
Hello, I am doing a steady-state sim and I want to define a normal velocity on an outlet which is the inside face of a cylinder. So I'm trying to use the fixedNormalInletOutletVelocity condition in my U file for this outlet. But I can't find information on how to set a constant value of the magnitude (e.g. 0.1 m/s), the API guide just mentions a time-varying sine function. Does anyone know how to write this U boundary condition for a constant normal velocity?
Alternatively, is there a way to define a mass flow on the outlet that is spread evenly ? (rather than some faces with a much higher mass flow than others)
Thank you
Ibrahim_I is offline   Reply With Quote
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
using outlet velocity profile as inlet for next set of iterations tricha122 FLUENT 0 November 22, 2020 10:40
Target Mass Flow Rate option for Pressure Outlet Tianyi STAR-CCM+ 11 October 23, 2019 07:56
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 16:57
