3D channel flow cyclic BC's pisoFOAM
Old   November 6, 2024, 08:33
Default 3D channel flow cyclic BC's pisoFOAM
Sjors Kremer
sjorskremer is on a distinguished road
Anybody that can help me out with the following problem?
I want to simulate turbulence in a 3D channel (steady flow).
The similationtype is RAS and the RASModel is LienCubucKE (nonlinear k-eps)
in the blockMeshDict:
I have setup the bottom, top, left and right as a wall type. The inlet and outlet are setup as a cyclic type. and the following dimensions:
// L:length, H:height, W:width
L 20;
H 0.1;
W 1;
blocks
hex ( 0 1 2 3 4 5 6 7) (20 10 100) simpleGrading (1 1 1)
In the 0 files:
the U, p, nut, k and epsilon all seem to be setup properly (with cyclic inlet and outlet).
I am using pisoFOAM (mandatory for this assignment). However, a very small dT (0.0005) gives a Courant number of 23 after 1.5 seconds, and increasing the dT leads to the following error:
--> FOAM FATAL ERROR: (openfoam-2406)
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux : 2.2607073
Specified mass inflow : 4.2978406e-08
Specified mass outflow : 0
Adjustable mass outflow : 8.0379753e-17
From bool Foam::adjustPhi(Foam::surfaceScalarField&, const volVectorField&, Foam::volScalarField&)
in file cfdTools/general/adjustPhi/adjustPhi.C at line 110.
FOAM exiting
Now i dont now what i can do to fix it??
sjorskremer is offline   Reply With Quote
Old   November 7, 2024, 16:51
Shravan
Severus is on a distinguished road
Do you apply a body force term that drives the flow? If you have cyclic boundary conditions for pressure, you will not have a pressure gradient to drive the flow and hence you need to use meanVelocityForce in fvOptions or fvConstraints file (depending on the version of OpenFOAM you use).
Check these links
https://develop.openfoam.com/Develop...tant/fvOptions
https://github.com/OpenFOAM/OpenFOAM.../fvConstraints
https://caefn.com/openfoam/fvoptions-meanvelocityforce
One other suggestion, instead of specifying deltaT, use adjustTimeStep option and provide a maximum Courant number, so that the solver will adjust the time step so that the maximum
Courant number limit is satisfied.
https://www.openfoam.com/documentati...output-control
Thanks
Severus is offline   Reply With Quote
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 22:36
Plane Poiseuille Flow (Channel Flow) with cyclic BC's irwin OpenFOAM 1 April 28, 2021 15:48
Enabling Open Channel Flow Sub-Model in Mixture model cod213 FLUENT 0 January 10, 2017 14:40
Simulating a Laminar Isothermal Flow in a 2D rectangular Channel HectorRedal Main CFD Forum 1 December 18, 2016 12:41
Modeling the mixing of air and kerosene in a flow channel StefanG CFX 3 June 11, 2012 21:21
