How to set fully developed velocity profile at inlet in OpenFOAM 12?
Old   November 10, 2024, 09:04
Default How to set fully developed velocity profile at inlet in OpenFOAM 12?
Wesley T.
Wesley is on a distinguished road
would like to create apply a fully developed velocity profile at the inlet to my simulation.
I am currently using OpenFOAM 12 and I have not yet found how to do this.
I have tried several approaches without success.
For comparison, in OpenFOAM 9, applying this inlet condition:
    Inlet
        type                flowRateInletVelocity;
        volumetricFlowRate  3.39e-5;
        extrapolateProfile  yes;
        value               uniform (0 0 0);
would result in this inlet velocity profile (scaled to the velocity profile of the inlet):
This same information in OpenFOAM 12 results in a uniform inlet velocity (scale is from 0 to the average velocity across the inlet):
I have not yet found how to create a fully developed velocity profile at the inlet.
Thank you for any help you can give to me to get a fully developed velocity profile with OpenFOAM 12.
Edited to add: Until I can get a developed velocity profile at the inlet, I will be using an added length of flow with the slip boundary condition. This will deliver a somewhat developed velocity profile and will not result in very high pressures at the outer circumference of the inlet where the flow is in contact with the walls (noSlip) of the simulation.
Last edited by Wesley; November 10, 2024 at 09:07. Reason: Adding the workaround I will be using, in case it is helpful to others
Wesley is offline   Reply With Quote
Old   October 27, 2025, 19:01
Russ Moerland
rmoerland is on a distinguished road
Not sure if you found the solution, but it appears what you're looking for is the 'profile' option to flowRateInletVelocity. This was committed by Henry on Jan 24, 2022. So, it should be in version 10 and later.
From the documentation:
Example of the boundary condition specification for a volumetric flow rate:
<patchName>
volumetricFlowRate 0.2;
profile laminarBL;
Example of the boundary condition specification for a mass flow rate:
<patchName>
massFlowRate 0.2;
profile turbulentBL;
rho rho;
rhoInlet 1.0;
rmoerland is offline   Reply With Quote
Old   November 2, 2025, 09:09
Default No solution yet
Wesley T.
Thank you for the suggestion, but it does not appear to give me the expected results. There is still not a developed flow at the inlet.
It is always possible I am overlooking something, so here is what I have for the U file at time 0:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  12
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    Inlet
        volumetricFlowRate  3.39E-05;
        profile laminarBL;
    Outlet
        type            zeroGradient;
    Walls
        type            noSlip;
Inlet velocity results for time = 0
Inlet velocity results for time = final (steady-state solution reached)
<patchName>
profile laminarBL;
<patchName>
massFlowRate 0.2;
rho rho;
rhoInlet 1.0;
Old   November 2, 2025, 15:50
Michael Häckel
michael_h is on a distinguished road
There are several tutorial which use flowRateInletVelocity successfully.
They are listed with foamInfo -a flowRateInletVelocity.
It is important that your "Walls" are "type wall" and not "type patch" in blockMeshDict or snappyHexMeshDict.
michael_h is offline   Reply With Quote
Old   November 3, 2025, 07:08
Default Setting type to "wall" in constant/polyMesh/boundary worked
Wesley T.
michael_h, thank you for the guidance.
I followed your comment on the "Walls" allowed the inlet velocity profile to create the developed velocity profile at the inlet.
I use Salome to generate the geometries I am simulating. To change the type, I went to the /constant/polyMesh directory and modified the type from what had been "patch" to "wall".
    Walls
        type            wall;
        nFaces          3248;
        startFace       64940;
There is now a developed velocity profile at the inlet, as shown below.
extrapolateprofile
Fully developed temperature profile at tube inlet amrkaood FLUENT 0 September 1, 2020 06:11
fully developed turbulent flow at inlet using mapped BC atul1018 OpenFOAM Running, Solving & CFD 0 August 21, 2020 06:44
UDF Velocity profile at inlet aar007 Fluent UDF and Scheme Programming 1 June 28, 2020 23:43
Pressure profile in Velocity inlet Pertica FLUENT 3 June 15, 2020 09:30
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
