Setting up alphaContactAngle in 2D Axissymmetric Case
Old   December 30, 2024, 10:14
Default Setting up alphaContactAngle in 2D Axissymmetric Case
Kurnibald is on a distinguished road
Hello everyone,
I'm trying to set up a droplet impact case as an 2D axis symmetric case.
The basic case is running and working as long as i use interFoam with incompressibleVoF solver.
However as soon as I try to implement the alphaContactAngle boundary condition I get either the error stating that only contactAngle is allowed:
(using InterFoam incompressibleVoF solver)
--> FOAM FATAL IO ERROR:
Unknown patchField type alphaContactAngle for patch substrate of type wall for field alpha.water
Valid patchField types are :
Or if I run the case with foamrun using incompressibleMultiphaseVoF solver I get this Backtrace.
Create time
Create mesh for time = 0
Selecting solver incompressibleMultiphaseVoF
Selecting viscosity model constant
Generating stack trace...
Backtrace:
    ZN10StackTraceC1Ev [0x7ffda24a1805+0x25]
         module: E:\blueCFD-Core-2024\ThirdParty-12\platforms\mingw_w64Gcc122DPInt32\lib\libstack_trace.dll
    ZN4Foam5error10printStackERNS_7OstreamE [0x7ffd7bc1c0dc+0x23c]
         module: E:\blueCFD-Core-2024\OpenFOAM-12\platforms\mingw_w64Gcc122DPInt32Opt\lib\libOpenFOAM.dll
    ZN4Foam6sigFpe13sigFpeHandlerEi [0x7ffd7bc1c774+0x34]
    (No symbol) [0x7ff6fcf92982]
         module: E:\blueCFD-Core-2024\OpenFOAM-12\platforms\mingw_w64Gcc122DPInt32Opt\bin\foamRun.exe
    _C_specific_handler [0x7ffda6cd7ff8+0x98]
         module: C:\WINDOWS\System32\msvcrt.dll
    0_chkstk [0x7ffda7e928bf+0x11f]
         module: C:\WINDOWS\SYSTEM32\ntdll.dll
    RtlRaiseException [0x7ffda7e42554+0x484]
    KiUserExceptionDispatcher [0x7ffda7e913ce+0x2e]
    ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_ [0x7ffd7bbb88ee+0x1e]
    ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_RKS7_ [0x7ffd887aebe0+0x3f0]
         module: E:\blueCFD-Core-2024\OpenFOAM-12\platforms\mingw_w64Gcc122DPInt32Opt\lib\libincompressibleMultiphaseVoF.dll
    ZN4Foam34incompressibleMultiphaseVoFMixture7correctEv [0x7ffd887472b9+0x209]
    ZN4Foam34incompressibleMultiphaseVoFMixtureC1ERKNS_6fvMeshE [0x7ffd887478f5+0x365]
    ZN4Foam7solvers27incompressibleMultiphaseVoFC1ERNS_6fvMeshE [0x7ffd887641b9+0x39]
     ZN4Foam6solver27addfvMeshConstructorToTableINS_7solvers27incompressibleMultiphaseVoFEE3NewERNS_6fvMeshE  [0x7ffd887a3465+0x25]
    ZN4Foam6solver3NewERKNS_4wordERNS_6fvMeshE [0x7ffd7a3ce5cb+0x1ab]
         module: E:\blueCFD-Core-2024\OpenFOAM-12\platforms\mingw_w64Gcc122DPInt32Opt\lib\libfiniteVolume.dll
    (No symbol) [0x7ff6fcf9431e]
    (No symbol) [0x7ff6fcf912ee]
    (No symbol) [0x7ff6fcf91406]
    BaseThreadInitThunk [0x7ffda7317374+0x14]
         module: C:\WINDOWS\System32\KERNEL32.DLL
    RtlUserThreadStart [0x7ffda7e3cc91+0x21]
I also build a blockmesh file for a flat droplet impact in 2D planar.
I basically changed the damBreak4phase case to two phases and this is running fine as long as i do not implement the uTheta thetaA and TheatR
--> FOAM FATAL ERROR:
The alphaContactAngle boundary conditions specified on patch leftWall for alpha.water and alpha.air contain inconsistent properties
    From function void Foam::correctContactAngle(const volScalarField&, const volScalarField&, const GeometricField<Vector<double>, fvPatchField, volMesh>::Boundary&, const dimensionedScalar&, GeometricField<Vector<double>, fvsPatchField, surfaceMesh>::Boundary&)
    in file correctContactAngle/correctContactAngle.C at line 92.
      FOAM exiting
So questions arise:
What does the Backtrace mean in case of using incompressibleMultiphaseVoF solver?
Can I use alphaContactAngle in a 2D axis symmetrical cases? ( I guess so since OF always uses a 3D Mesh and the paper i want to compare to does so as well)
Why can I not use alphaContactAngle in my axis symmetrical case and only get the option to choose contactAngle using InterFoam incompressibleVoF solver?
--> Answered myself: it is only implemetned with multiphase solvers see: https://doc.openfoam.com/2312/tools/...aContactAngle/
Why does openfoam complain about inconsistent properties in the flat case? (I tried a few different values adding up to 90°)
What does the value 1 or 0 do at the end of the alphaContactAnlge do?
    substrate
        type            alphaContactAngle;
        contactAngleProperties
            air             { theta0 90; uTheta 0.1; thetaA 60; thetaR 30;}
        value           uniform 0;
        limit            alpha;
I'm getting a bit frustrated, I've set up the case completely new multiple times. Basically it is a damBreak4phase case adapted to a axis symmetrical mesh with only one block which works as long as i don't implement the alphaContactAngle.
I use blueCFD-Core-2024-1 on Windows 10 Pro
which according to blueCFD is OpenFOAM 12
My 0/alpha files:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  12
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       volScalarField;
    location    "0";
    object      alpha.air;
dimensions      [];
internalField   uniform 0;
boundaryField
    atmosphere
        type            inletOutlet;
        inletValue      $internalField;    //or uniform 0;
        value           $internalField; //or uniform 0;
    substrate
        value           uniform 0;
        limit            alpha;
//    substrate
//      type            contactAngle;
//      theta0             90;
//        UTheta             1;
//        thetaA             30;
//        thetaR             60;
//        limit            alpha;
//        value            $internalField;
//    substrate
//        theta0             30;
//        limit            alpha;
//    substrate
//        type            zeroGradient;
    front
        type            wedge;
    back
        type            wedge;
    axis
        type    empty;
     \\/     M anipulation  |
FoamFile
    format      ascii;
    location    "0";
    object      alpha.water;
dimensions      [];
boundaryField
    atmosphere
        type            inletOutlet;
        inletValue      $internalField;    //or uniform 1;
        value           $internalField; //or uniform 1;
    substrate
            water           { theta0 90; uTheta 0.1; thetaA 60; thetaR 30;}
        value           uniform 0;
        limit            alpha;
//    substrate
//      theta0             90;
//        UTheta             1;
//        thetaA             30;
//        thetaR             60;
//        limit            alpha;
//    substrate
//        theta0             value 90;
//        limit            alpha.water;
//        value            1;
//    substrate
    front
        type            wedge;
    back
        type            wedge;
    axis
        type    empty;
Kurnibald is offline   Reply With Quote
[snappyHexMesh] Setting up a case using .stl files MichaelO OpenFOAM Meshing & Mesh Conversion 1 July 6, 2020 09:54
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Setting up Case for different turbulence models with buoyancy-driven flow MisterX OpenFOAM Running, Solving & CFD 0 November 19, 2012 06:26
Setting up a turbine nozzle case cfdengineer CFX 2 August 2, 2010 06:49
