[Sponsors] | |||||
topoSet is not generating the correct number of interfaces |
Hasan
Rep Power: 0 ![]() |
I want to model the temperature impact of a fluid in a tube on the outer domain and am using the blockMeshDict and topoSetDict below. blockMeshDict: Code:
| \\ / O peration | Version: v2212 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
scale 1;
vertices
(0 0 0) //0
(0.108 0 0) //1
(0.122 0 0) //2
(1 0 0) //3
(1 0.108 0) //4
(1 1 0) //5
(0.086 1 0) //6
(0 1 0) //7
(0 0.122 0) //8
(0 0.108 0) //9
(0.076 0.076 0) //10
(0.086 0.086 0) //11
(0 0 10) //12
(0.108 0 10) //13
(0.122 0 10) //14
(1 0 10) //15
(1 0.108 10) //16
(1 1 10) //17
(0.086 1 10) //18
(0 1 10) //19
(0 0.122 10) //20
(0 0.108 10) //21
(0.076 0.076 10) //22
(0.086 0.086 10) //23
blocks
hex (12 13 1 0 12 21 9 0) (5 5 10) simpleGrading (1 1 1)
hex (13 14 2 1 21 20 8 9) (5 5 10) simpleGrading (1 1 1)
hex (14 15 3 2 23 16 4 11) (5 5 10) simpleGrading (1 1 1)
hex (23 16 4 11 18 17 5 6) (5 5 10) simpleGrading (1 1 1)
hex (20 23 11 8 19 18 6 7) (5 5 10) simpleGrading (1 1 1)
edges
arc 1 9 (0.076 0.076 0)
arc 13 21 (0.076 0.076 10)
arc 2 8 (0.086 0.086 0)
arc 14 20 (0.086 0.086 10)
boundary
inlet
type patch;
faces
(0 1 9 0)
outlet
type patch;
faces
(12 13 21 12)
symmetryFacesFluid
type patch;
faces
(12 13 1 0) (12 21 9 0)
symmetryFacesDomain
type patch;
faces
(14 15 3 2) (15 16 4 3) (16 17 5 4) (18 17 5 6) (19 18 6 7) (20 19 7 8) (2 3 4 11) (11 4 5 6) (8 11 6 7) (14 15 16 23) (23 16 17 18) (20 23 18 19)
Casing
type wall;
faces
(13 14 20 21) (1 2 8 9) (13 14 2 1) (21 20 8 9) (14 20 8 2) //(13 21 9 1)
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
//tube
name tube;
type cellSet;
action new;
source cylinderToCell;
point1 (0 0 0);
point2 (0 0 10);
radius 0.108;
innerRadius 0.0;
name tube;
type cellZoneSet;
action new;
source setToCellZone;
sourceInfo
{set tube;}
//metal
name metal;
type cellSet;
action new;
point1 (0 0 0);
point2 (0 0 10);
radius 0.122;
innerRadius 0.108;
name metal;
type cellZoneSet;
action new;
sourceInfo
{set metal;}
//whole domain
name domain;
type cellZoneSet;
action clear;
name domain;
type cellSet;
action add;
source cellToCell;
sourceInfo
{set metal;}
name domain;
type cellSet;
action add;
source cellToCell;
sourceInfo
{set tube;}
name domain;
type cellSet;
action invert;
name domain;
type cellZoneSet;
action new;
sourceInfo
{set domain;}
splitMeshRegions log file: Code:
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Trying to match regions to existing cell zones.
Number of regions:3
Writing region per cell file (for manual decomposition) to "/home/hasan/openFoam/cryogenicInjection/cryogenicinjection_modified/constant/cellToRegion"
Writing region per cell as volScalarField to "/home/hasan/openFoam/cryogenicInjection/cryogenicinjection_modified/0/cellToRegion"
Region Cells
0 250
1 250
2 750
Region Zone Name
0 (0) tube
1 (1) metal
2 (2) domain
Sizes of interfaces between regions:
Interface Region Region Faces
0 0 1 50
Reading volScalarField: cellToRegion
Adding patches
Adding patches
For interface between region tube and metal added patches
6 tube_to_metal
7 metal_to_tube
Region 0
Creating mesh for region 0 tube
Writing dummy "tube/fvSchemes"
Writing dummy "tube/fvSolution"
Mapping fields
Mapping field cellToRegion
Deleting empty patches
Writing new mesh
Writing addressing to base mesh
Writing map pointRegionAddressing from region0 points back to base mesh.
Writing map faceRegionAddressing from region0 faces back to base mesh.
Writing map cellRegionAddressing from region0 cells back to base mesh.
Writing map boundaryRegionAddressing from region0 boundary back to base mesh.
Region 1
Creating mesh for region 1 metal
Writing dummy "metal/fvSchemes"
Writing dummy "metal/fvSolution"
Mapping fields
Writing new mesh
Writing map pointRegionAddressing from region1 points back to base mesh.
Writing map faceRegionAddressing from region1 faces back to base mesh.
Writing map cellRegionAddressing from region1 cells back to base mesh.
Writing map boundaryRegionAddressing from region1 boundary back to base mesh.
Region 2
Creating mesh for region 2 domain
Writing dummy "domain/fvSchemes"
Writing dummy "domain/fvSolution"
Mapping fields
Writing new mesh
Writing map pointRegionAddressing from region2 points back to base mesh.
Writing map faceRegionAddressing from region2 faces back to base mesh.
Writing map cellRegionAddressing from region2 cells back to base mesh.
Writing map boundaryRegionAddressing from region2 boundary back to base mesh.
End
H |
| Tags |
| interface, splitmeshregions, toposetdict |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
| SimpleFoam & Theater | jipai | OpenFOAM Running, Solving & CFD | 3 | June 18, 2019 11:11 |
| Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
| [blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
| Doxygen documentation | Tanay | OpenFOAM Installation | 9 | September 23, 2011 12:40 |
