internalField nonuniform list issues (on alpha.* / phase initialization)
Old   January 9, 2025, 03:23
Default internalField nonuniform list issues (on alpha.* / phase initialization)
Markus S.
Confluks is on a distinguished road
Hey there,
I'm trying to make use of a multiphase simulation (via interFoam) in OpenFoam 10. Before, I try to initilize different phases on the mesh. I specified the phases in "0" directory as well as the setFieldsDict. Then I run setFields function (after generating mesh of course).
The file alpha.* should be edited and must now contain a list of zeros and ones under the entry internalField. (I'm just using 2 phases here)
So, here is an example of what I would expect:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  10
     \\/     M anipulation  |
FoamFile
    format      binary;
    class       volScalarField;
    location    "0";
    object      alpha.methanol;
dimensions      [0 0 0 0 0 0 0];
internalField   nonuniform List<scalar>
32400
(0
1
1
0
1
1
1
0
0
Unfortunately, when I run this function my file looks like this:
     \\/     M anipulation  |
FoamFile
    format      binary;
    location    "0";
32400
Apparently, the formating is kinda off. Although, I don't get an error or warning massage using setFields:
     \\/     M anipulation  |
Build  : 10-c4cf895ad8fa
Exec   : setFields
Date   : Jan 08 2025
Time   : 14:37:39
Host   : "DESKTOP-NGKFP5B"
PID    : 40467
I/O    : uncollated
Case   : [...]
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading "setFieldsDict"
Setting field default values
    Setting internal values of volScalarField alpha.methanol
Setting field region values
    Adding cells with center within boxes 1((0 0 -1) (0.001 0.00025 1))
End
Honestly, it looks like a formating issue but since the file is edited by OF functions it should be the correct format.
The entry is valid anyway since I am able to call interFoam and calculate the case. Also, I can see the initilized phases in Paraview.
Does anybody faced the same issue? Is there a "fix" or why it is appearing like this?
Looking forward to your replys
Cheers
Markus
Confluks is offline   Reply With Quote
Old   January 10, 2025, 05:13
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Markus,
The file has been written in binary format, so it is easily read by the computer, but not so much by a human. If you would change the controlDict to have
writeFormat        ascii;
you will have a human-readable version of the file after running setFields.
However, these files will be bigger and less accurate (depending on writePrecision), so I would recommend leaving it to binary.
For testing/checking purposes, ascii can be used of course.
Regards,
Tom
tomf is offline   Reply With Quote
Old   January 13, 2025, 03:55
Markus S.
Hi Tom,
Thanks for your reply. That’s pretty much what I thought. And yes, it’s mainly for a test case configuration. I can also check it in ParaView, where it’s displayed correctly. However, I was just curious whether this behavior is intentional or not.
Also, thanks for the hint about ASCII formatting—that’ll definitely help for now.
Cheers,
Markus
issues when using nonuniform List at inlet haow OpenFOAM Pre-Processing 0 July 2, 2018 14:33
Issues with symmetry patches perpendicular to outlets sturgeon OpenFOAM Running, Solving & CFD 2 October 9, 2017 10:46
Issues with volume of fluid in three phase simulation hooman.esl FLUENT 0 July 17, 2017 08:30
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
