createPatch after createBaffles error due to zero-face patches having been removed
Old   January 24, 2025, 14:59
Default createPatch after createBaffles error due to zero-face patches having been removed
Mars409 is on a distinguished road
Running createPatch after createBaffles runs into fatal error that complains of non-couple patches not found, which is due to the zero-face patches, which result from the baffle's back-to-back patches having all their faces remove to newly created nonconformal counterpart patches but still retained b/c the latter still refer back to them as originalPatch, having all been removed by createPatch's filterPatches() then all remaining patches reconstituted, upon which the nonconformal counter patches cannot find the originalPatch.
Commenting ouf the call to filterPatches() in createPatches's main() resolves the error.
Mars409 is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? ptpacheco OpenFOAM Meshing & Mesh Conversion 1 January 4, 2022 12:37
Simulating fire in a tunnel luca1992 OpenFOAM 14 August 16, 2017 13:50
OF ext-3.2 new createPatch cyclics issue Jack001 OpenFOAM Pre-Processing 0 May 26, 2016 14:43
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
