fvOptions CellSet was not declared in this scope
Old   January 26, 2025, 01:49
Default fvOptions CellSet was not declared in this scope
defeatedUniStudent is on a distinguished road
I am trying to input a momentum source through fvOptions into a cellSet. In topoSetDict i created a CellSet called plasmaCellSet and a cellZone called plasma. When i try to use plasmaCellSet in fvOptions i get an error saying it is not within the scope and suggests smCellSet? How do I get fvOptions to recognize plasmaCellSet? Thank you!!
/home/user1/withTurb/constant/fvOptions/actuatorForceSource/vectorCodedSourceCoeffs: In member function ‘virtual void Foam::fv::actuatorForceSourceFvOptionvectorSource: :addSup(Foam::fvMatrix<Foam::Vector<double> >&, Foam::label)’:
/home/user1/withTurb/constant/fvOptions/actuatorForceSource/vectorCodedSourceCoeffs:47:33: error: ‘plasmaCellSet’ was not declared in this scope; did you mean ‘smCellSet’?
/home/user1/withTurb/constant/fvOptions/actuatorForceSource/vectorCodedSourceCoeffs:60:79: error: ‘class Foam::cellSet’ has no member named ‘V’
make: *** [/usr/lib/openfoam/openfoam2412/wmake/rules/General/transform:38: Make/linuxARM64GccDPInt32Opt/codedFvOptionTemplate.o] Error 1
--> FOAM FATAL IO ERROR: (openfoam-2412)
Failed wmake "dynamicCode/actuatorForceSource/platforms/linuxARM64GccDPInt32Opt/lib/libactuatorForceSource_68faa9f8dc0a8c5f007d185c578 bf4d190b12a44.so"
file: constant/fvOptions/actuatorForceSource/vectorCodedSourceCoeffs at line 27 to 66.
From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
in file db/dynamicLibrary/codedBase/codedBase.C at line 245.
FOAM exiting
| \\ / O peration | Version: v2412 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
//Plasma
name plasmaCellSet;
type cellSet;
action new;
source boxToCell;
sourceInfo
//location of plasma, AKA//
//second actuator, use Charlie's point thing to find//
min (0.05 0.005294 0);
max (0.07 0.007994 0.05);
name plasma;
type cellZoneSet;
action new;
source setToCellZone;
sourceInfo
set plasmaCellSet;
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvOptions;
#include "../system/topoSetDict"
actuatorForceSource
type vectorCodedSource;
active true;
name actuatorForceSource;
selectionMode cellSet;
cellSet plasmaCellSet;
fields (U); //Modify field U
codeInclude
#include "topoSet.H"
#include "cellSetOption.H"
#include "cellSet.H"
#include "fvMesh.H"
#include "volFields.H"
codeCorrect
Pout<< "**codeCorrect**" << endl;
codeAddSup
cellSet selectedCells = (mesh_, plasmaCellSet);
labelList cells = selectedCells.toc ();
const Time& time = mesh().time();
const scalar pi(M_PI);
const scalar f_base = 2e3;//Hz base frequency
const scalar startTime = 2.0;//s
vectorField& Su = eqn.source();
if(time.value() > startTime)
UIndirectList<vector>(Su, cells) = vector(0.006705, 0, 0) / selectedCells.V();
eqn.source() += Su * pow(sin(2*pi*f_base*time.value()), 2);
codeConstrain
Pout<< "**codeConstrain**" << endl;
defeatedUniStudent is offline   Reply With Quote
Old   January 29, 2025, 10:28
Tobermory will become famous soon enough
You have the following in your fvOptions file
Remove that, run topoSet (which will operate on the topoSetDict and generate the plasmaCellSet and plasma sets under constant/polymesh/sets) and then run your simulation - it will now be able to pick up plasma cellZone set
Tobermory is offline   Reply With Quote
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 08:43
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
