Problem with rotating wheels
Old   January 30, 2025, 11:53
Default Problem with rotating wheels
Slashim is on a distinguished road
Hi guys,
I have a problem with a university project for the CFD for a truck. I impose on the boundary condition in U for the wheels this conditions:
Wheel_11
type rotatingWallVelocity;
origin (1.41 0 0.5);
axis (0 1 0);
omega -$rotation; // Rotational speed in radians/sec
uniform (0 0 0);
Wheel_12
origin (5 0 0.5);
axis (0 1 0);
uniform (0 0 0);
Wheel_13
origin (5 0 0.5);
axis (0 1 0);
uniform (0 0 0);
I run the simulation, then on paraview I cannot always visualize the rotation of the wheel (sometimes appear and then disappear)
Can someone help me?
Thank you very much
Slashim is offline   Reply With Quote
Old   January 30, 2025, 12:16
Yann
Yann will become famous soon enoughYann will become famous soon enough
Can you elaborate on this and show us what you get?
Yann is offline   Reply With Quote
Old   January 30, 2025, 12:34
Yes sure
https://imgur.com/a/ADpJo0s
Old   January 30, 2025, 12:52
Yann
Looks like the condition is properly applied on some wheels but not all wheels, right?
First things coming to mind:
  1. Look for any mismatch between the wheels names in your mesh and in your boundary conditions (look for typos, remember OpenFOAM is case sensitive)
  2. Double check origin coordinates to make sure you didn't mix things up
Old   January 30, 2025, 12:56
No, the screen are on the same simulation at the same final iteration, but for some reasons sometimes I can visualize the rotation and sometimes no.
The coordinates are correct I am sure and I check all the files of my simulation
Old   January 30, 2025, 13:01
Yann
What are you displaying on the screen ? the volume mesh or the patches?
What do you get if you load only the patches in the "mesh regions" section in ParaView?
Old   January 30, 2025, 16:09
I was displayng the internal mesh , not the patches. If I display only the patches I can see the rotation of all the tires. Is it ok for my simulation?
Old   January 31, 2025, 04:02
Yann
Sure it is!
If you want to see both at the same time, you can load patches and internalMesh in paraView, and then use the "Extract Block" filter to select either internalMesh or whatever patch(es) you want to see.
Cheers!
Rotating domain problem ColourfulPost Main CFD Forum 9 November 8, 2020 10:23
Error in the problem with a rotating wheel and a contact patch KAYANO OpenFOAM Running, Solving & CFD 0 April 11, 2020 04:34
Rotating problem / transient / 2D Logan86 CFX 6 July 8, 2011 07:57
Problem with rotating SOLID domain Roland R CFX 0 May 8, 2009 04:38
Rotating Vessel: Problem Set-Up Harmeet FLUENT 0 February 4, 2005 06:41
