[Sponsors] | |||||
Gerald
Rep Power: 0 ![]() |
Hello all, I am simulating the pressure wave in a room resulting from a heat source.
I want to create a geometry of a box within a box with a hole that allows gas to escape from the smaller box (where the heat source is in). I first made the large box using blockMesh and made the small box with internal faces using topoSet and createBaffles. What left me confused was when I had to create a patch for the "hole" since it has to both function as an inlet and outlet. Should it also be created using topoSet and createBaffles? If so, how would it be known which faces are the "inlet" and "outlet" for the fluid? I've also attached a picture showing the big box and small box that I've managed to make so far. Thanks! |
| Tags |
| blockmesh, createbaffles, inlet, outlet, toposet |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 7 | September 18, 2024 06:52 |
| PIMPLE Stability | CallumG | OpenFOAM Running, Solving & CFD | 3 | July 16, 2022 05:17 |
| Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 16:20 |
| [Other] dynamicTopoFVMesh and pointDisplacement | RandomUser | OpenFOAM Meshing & Mesh Conversion | 6 | April 26, 2018 08:30 |
| Inlet patch problems | martyn88 | OpenFOAM Running, Solving & CFD | 6 | April 21, 2017 19:34 |
