Problem using redistributePar in collated mode
Old   February 4, 2025, 07:19
Default Problem using redistributePar in collated mode
RocketScientist is on a distinguished road
Dear foamers,
I am facing a problem running redistributePar on a HPC cluster in collated mode using OF2206.
I am using redistributePar to profit from parallel decomposition and reconstruction. This works flawlessly in uncollated mode but I am running into the inode cap. Therefore, I tried using the collated mode to reduce the amount of files generated by OpenFOAM.
I tried adding the -fileHandler option in the Slurm script as follows
mpirun redistributePar -decompose -fileHandler collated -parallel
and also to include it in the controlDict by adding the following entry with and without the maxThreadFileBufferSize entry.
OptimisationSwitches
    fileHandler collated;
    maxThreadFileBufferSize 1e9;
However, when running the redistributePar tool, it always hangs at
Setting caseName to [...] to read undecomposed mesh
without posting any error message.
Does anybody have an idea how to resolve this issue?
Thank you guys for your help!
RocketScientist is offline   Reply With Quote
Old   February 11, 2025, 05:50
Adrian
Henrinavier is on a distinguished road
Hey RocketScientist,
I once ran into a similar problem and circumvented it by reverting back to uncollated mode. Sadly, no "real solution" if you need to reduce the directoriy count.
If someone has a real solution, I'd be interested too...
Best regards,
Henrinavier
Henrinavier is offline   Reply With Quote
collated, redistributepar
Foam-extend crashes with custom BC, but works fine in Debug mode Arman_N OpenFOAM Programming & Development 7 September 26, 2020 02:51
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
CHTMultyRegionFoam - BC problem? Carlo_P OpenFOAM Running, Solving & CFD 0 October 30, 2019 09:54
[Workbench] 'Batch mode' ICEM CFD problem 86682164 ANSYS Meshing & Geometry 0 August 22, 2013 17:53
problem with running UDF in batch mode James FLUENT 0 June 6, 2006 07:49
