Problem with contact angle
Old   February 4, 2025, 10:21
Default Problem with contact angle
Borja DG
Borja is on a distinguished road
Hi Everyone,
When I initialise a vapour and water field that is meant to have a 50 degree contact angle at the wall it looks as follows (please see attachment). Note that the white line through the gradient is an interpolated interface representation of alpha = 0.5
Now, I am using a constant contact angle BC at the bottom wall, which I understand is based on the gradient of the phase field at the boundary. As I said, I set it to 50, but it looks more like an 80 degree angle (?). This is time 0, and I have checked my initial conditions over and over again. Does anyone have a clue of what that could be?
Note that the line through the rest of the interface is indeed at 50 degrees, the problem only arises when it reaches the bottom wall...
Thanks!
Borja
Borja is offline   Reply With Quote
boundary condition, contact angle, initial condition, interfoam
Contact angle in Wire DED model ZhengmingW FLOW-3D 0 May 22, 2024 22:38
multiphase flow - contact angle manjunath88 Fluent UDF and Scheme Programming 6 January 17, 2017 05:34
Contact angle between different phase and wall liguifan OpenFOAM Pre-Processing 1 March 7, 2013 03:46
Ansys Workbench contact problem! JoelHenrik ANSYS 1 October 1, 2010 15:57
About the Contact Angle Flora FLUENT 2 March 8, 2007 03:07
