[Sponsors] | |||||
Daniel
Rep Power: 3 ![]() |
i am doing research on the pressure drop due to rapid diameter expansion of pipes for small Reynoldsnumbers (laminar flow). My geometry/mesh can be seen in the attachments. First i tried a structured Mesh with cyclic boundary conditions. The segment itself is 45°. I did this to save computation time bc its an Axisymmetric flow type. But something strange happens. The Line which is also the symmetry axis seems to do strange things. I looked up a few tutorials and there they defined the centerline curve as physical curve in Blockmesh-then its set to empty in the constant/polyMesh/boundary file. I tried to do the same in GMSH but after gsmhToFoam import there is no Axis entry. Nevertheless i came across another Model- Axisymmetric flow wiht wegde boundary condition for the sides. This works perfectly fine for my case. I did follow these instructions : https://openfoamwiki.net/index.php/M...s/AxiSymmetric BUT - i wanted to check if the results match up with a real 3D simulation with a unstructured mesh. The velocity for in and outlet are nearly equal. But the inletPressure is in the 3D case a lot higher then in the axisymmetric case with the wedge bc. I am wondering what am i doing wrong. 1.: why is the case with the cyclic bc not working properly 2.: why is there a huge difference between the inletPressure (3D compared to axisymmetric with wedge bc) 3.: i implemented the fully developed inlet condition using codedFixedValue bc i need a parabolic inlet velocityprofile. I think its working fine but there is a little difference in the gradient near the wall- i will include a picture. So is the velocityprofile implemented correct. here are my used boundary conditions p/U for the cyclic case: Code:
| \\ / O peration | Version: v2312 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type zeroGradient;
value uniform 0;
outlet
type fixedMean;
meanValue 0;
value uniform 0;
wall
type zeroGradient;
"(cyclic_0|cyclic_1)"
type cyclic;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type codedFixedValue;
value uniform (0 0 0);
name inletLaminarProfil;
code
const fvPatch& boundaryPatch = patch(); //generic
const vectorField& Cf = boundaryPatch.Cf(); //generic
vectorField& field = *this; //generic
const scalar yc = 0; // definition of the center y coordinate
const scalar rpipe = 0.00025; // definition of the pipe radius
const scalar Umax = 0.596; // definition of the maximum velocity Re=10
forAll(Cf, faceI) // loop over all the patch faces
// const scalar x = Cf[faceI].x(); // x coordinate of the faces i
const scalar y = Cf[faceI].y(); // y coordinate of the faces i
const scalar z = Cf[faceI].z(); // z coordinate of the faces i
const scalar radius = pow((y-yc)*(y-yc)+z*z,0.5); // compute radius from center patch
field[faceI] = vector( Umax *(1-pow(radius/rpipe,2)), 0, 0); // define velocity value on the face i
outlet
type zeroGradient;
wall
type noSlip;
type cyclic;
FoamFile
version 2.0;
format ascii;
class dictionary;
object createPatchDict;
// This application/dictionary controls:
// - optional: create new patches from boundary faces (either given as
// a set of patches or as a faceSet)
// - always: order faces on coupled patches such that they are opposite. This
// is done for all coupled faces, not just for any patches created.
// - optional: synchronise points on coupled patches.
// 1. Create cyclic:
// - specify where the faces should come from
// - specify the type of cyclic. If a rotational specify the rotationAxis
// and centre to make matching easier
// - always create both halves in one invocation with correct 'neighbourPatch'
// setting.
// - optionally pointSync true to guarantee points to line up.
// 2. Correct incorrect cyclic:
// This will usually fail upon loading:
// "face 0 area does not match neighbour 2 by 0.0100005%"
// " -- possible face ordering problem."
// - in polyMesh/boundary file:
// - loosen matchTolerance of all cyclics to get case to load
// - or change patch type from 'cyclic' to 'patch'
// and regenerate cyclic as above
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
// with transformations (i.e. cyclics).
pointSync false;
// Patches to create.
patches
// Name of new patch
name cyclic_0;
// Dictionary to construct new patch from
patchInfo
type cyclic;
neighbourPatch cyclic_1;
// Optional: explicitly set transformation tensor.
// Used when matching and synchronising points.
transform rotational;
rotationAxis (1 0 0);
rotationCentre (0 0 0);
rotationAngle 22.5;
// transform translational;
// separationVector (1 0 0);
// Optional non-default tolerance to be able to define cyclics
// on bad meshes
matchTolerance 1E-4;
// How to construct: either from 'patches' or 'set'
constructFrom patches;
// If constructFrom = patches : names of patches. Wildcards allowed.
patches (front);
name cyclic_1;
patchInfo
type cyclic;
neighbourPatch cyclic_0;
rotationAngle -22.5;
// on bad meshes
patches (back);
FoamFile
version 2.0;
format ascii;
object U;
boundaryField
inlet
type fixedValue;
value uniform (1 0 0);
inlet
code
outlet
type zeroGradient;
wall
type noSlip;
"(front|back)"
type wedge;
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
inlet
type zeroGradient;
value uniform 0;
outlet
type fixedMean;
meanValue 0;
value uniform 0;
wall
type zeroGradient;
"(front|back)"
type wedge;
FoamFile
version 2.0;
format ascii;
object U;
boundaryField
inlet
type fixedValue;
inlet
code
outlet
type zeroGradient;
wall
type noSlip;
"(front|back)"
type wedge;
FoamFile
version 2.0;
format ascii;
object p;
boundaryField
inlet
type zeroGradient;
value uniform 0;
outlet
type fixedMean;
meanValue 0;
value uniform 0;
wall
type zeroGradient;
"(front|back)"
type wedge;
Did i do something wrong with the implementation of U? or did i set my bc completely wrong? Hope someone could help me out. I cant explain myself why there is a huge difference in inlet pressure... even though the velocities match perfect for 3D and wedge case |
| Tags |
| codedfixedvalue, cyclic boundary condition, laminar flow, laminar flow in pipe, wedge mesh axisymmetric |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Does recirculation zone present in laminar flow? | swindlers | Main CFD Forum | 1 | May 11, 2024 14:53 |
| CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 08:08 |
| High velocity in Laminar flow | Manojmech | FLUENT | 0 | November 3, 2016 05:37 |
| Is it a turbulent flow or laminar flow? | ringtail | Main CFD Forum | 9 | January 22, 2015 20:52 |
| Test for a laminar flow in axisymmetric nozzle | Victor | Main CFD Forum | 0 | November 30, 2005 11:51 |
