mass flow rate boudary condition with cylinderical coordinate |
Rep Power: 3 ![]() |
Is there any mass flow rate boudary condition which I can set it's direction in cylindrical coordinate? Something like massflowrate in CFX for inlet? |
It seems like the cylindricalInletVelocity might be what you are looking for? Although it only specifies a velocity, not a flowrate. Cheers, Tom |
#3 | |
Also I have seen "cylindricalInletVelocity" which is similar to "swirlFlowRateInletVelocity"(using flow rate) but I can't understand how to import my tangential direction as the rpm. |
Well, those were the other candidates that I could think of. I guess it depends on your exact situation what might work.
There is the option of expressions. Or the coded option. Both have some syntax that needs to be studied carefully. Not sure if there is any example around. Regards, Tom |
cylindrical direction, mass flow |
Display Modes | |
rhoSimpleFoam with specified mass flow rate at outlet | ishan_ae | OpenFOAM Running, Solving & CFD | 3 | September 1, 2020 01:11 |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 08:38 |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 06:00 |
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 17:46 |
How can apply mass flow rate boundary condition? | Sima | Phoenics | 1 | December 1, 2007 18:55 |
