Using simulations results as inputs to a new simulation |
Hazem
Rep Power: 3 ![]() |
I have a simulation case (Case1) on a domain size (100*40*40) m^3. I want to get the fields at a specific YZ plane at x = 40 m at a specific timestep t_target, and use these values of the different fields as input boundary conditions to another case (Case2) on a domain size (60*40*40) m^3, and starting the simulation from t_target. I am trying to change the resolution at some region after x = 60 m, and instead of rerunning Case2 from the beginning for the whole length like Case1, I want to make use of the data generated from Case1 at certain location and timestep and feed them as inputs to Case2 on a smaller domain. I have looked into mapFields option, but what I found isn't helping in my goal. So, how can I do this? Thank you! |
map fields |
Display Modes | |
CFG file Set Up | Nicola_Fontana | SU2 | 5 | November 16, 2021 12:48 |
How to restart simulation using results from other solver | sahmed | OpenFOAM Running, Solving & CFD | 8 | July 5, 2019 06:02 |
SU2 Transonic Flow simulations bad results | S.Kontogiannis | SU2 | 12 | June 20, 2019 07:46 |
SU2 Transonic Flow simulations bad results | S.Kontogiannis | Main CFD Forum | 8 | May 16, 2014 12:22 |
interFoam simulation yields inconsistent results for alpha1 surface | Ralinus | OpenFOAM Running, Solving & CFD | 8 | January 13, 2014 08:54 |
