[Sponsors] | |||||
Chris
Rep Power: 0 ![]() |
Dear all,
I am currently running a transient simulation that requires me to save a large number of individual time steps. In order to avoid annoying our administrators I tried using the collated fileHandler option. While case setup, decomposition and post-processing work perfectly, the decomposition of a recomposed case does not. I have now experimented with some tutorial cases as I suspected that the problem lies with the dynamic mesh. Specifically, I ran the surfaceMountedCube and simpleRotor cases using the collated I/O option. While there are no problems with the surfaceMountedCube, the simpleRotor case reproduced the error I am getting on my actual case when trying to decompose again: Code:
[simpleRotor]$ decomposePar -latestTime -fileHandler collated
| \\ / O peration | Version: 2306 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _fbf00d6b-20230626 OPENFOAM=2306 version=2306
Arch : "LSB;label=32;scalar=64"
Exec : decomposePar -latestTime -fileHandler collated
Date : Oct 17 2025
Time : 08:52:54
Host :
PID :
I/O : collated [unthreaded] (maxThreadFileBufferSize = 0).
Writing may be slow for large file sizes.
Case : /collatedTest/simpleRotor
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStamp (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Overriding OptimisationSwitches according to controlDict
fileHandler (unregistered)
maxThreadFileBufferSize 2e+09;
maxMasterFileBufferSize 2e+09;
Decomposing mesh
Create mesh
Calculating distribution of cells
Decomposition method hierarchical [3] (region region0)
Finished decomposition in 0 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
maxThreadFileBufferSize 2000000000;
maxMasterFileBufferSize 2000000000;
Processor 0
Number of cells = 2069
Number of points = 4422
Number of faces shared with processor 1 = 108
Number of processor patches = 1
Number of processor faces = 108
Number of boundary faces = 4310
Processor 1
Number of points = 4560
Number of faces shared with processor 0 = 108
Number of faces shared with processor 2 = 108
Number of processor patches = 2
Number of processor faces = 216
Number of boundary faces = 4338
Processor 2
Number of cells = 2070
Number of points = 4424
Number of boundary faces = 4312
Max number of cells = 2070 (0.03221649485% above average 2069.333333)
Max number of processor patches = 2 (50% above average 1.333333333)
Max number of faces between processors = 216 (50% above average 144)
Time = 0.02
Processor 0: field transfer
Detected additional non-decomposed files in "/collatedTest/simpleRotor/0.02/uniform"
Processor 1: field transfer
--> FOAM FATAL IO ERROR: (openfoam-2306)
incorrect first token, expected <int>, found on line 26: error
file: processors3/0.02/meshPhi at line 26.
From Foam::Istream& Foam::List<T>::readList(Foam::Istream&) [with T = char]
in file primitives/chars/lists/charList.C at line 103.
FOAM exiting
p { margin-bottom: 0.1in; line-height: 115%; background: transparent }
Have any of you encountered this problem before and if so, is there a solution? Kind regards, Chris |
| Tags |
| collated |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [mesh manipulation] How to use a volScalarField as cellDisplacement input (dynamic mesh)? | ocean12 | OpenFOAM Meshing & Mesh Conversion | 0 | May 4, 2022 15:48 |
| Unsteady Restart Divergence | pro_ | SU2 | 6 | May 20, 2020 16:17 |
| Question about SU2 optimization | YoniHe | SU2 Shape Design | 3 | January 15, 2016 01:31 |
| CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 06:57 |
| Dynamic mesh + grid adapt = Crash! (Files included | BillH | FLUENT | 4 | July 24, 2007 16:31 |
