[Sponsors] | |||||
Flow does not pass through Non-Conformal Coupling (NCC) interface between nozzle, sub |
Mohammad Mesgar
Rep Power: 6 ![]() |
Hello everyone,
I am working with OpenFOAM v10 and using Non-Conformal Coupling (NCC) to connect two regions: a moving nozzle region and a stationary substrate region. The nozzle slides correctly over the substrate (mesh motion works and there is no element deformation), but no flow transfers across the NCC interface. What are the common reasons why NCC transfers mesh motion but not mass/pressure? I attached the test case. Any advice or example setups would be very helpful. Thank you! |
| Tags |
| ncc, openfoam |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Flow Rate over Sliding Interface | steve_heidra | FLUENT | 0 | January 9, 2025 13:11 |
| Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
| Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
| Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
| Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
