[Sponsors] | |||||
anonymous
Rep Power: 0 ![]() |
I am using OpenFOAM v2412 and have a question about p_rgh divergence in
Case description Closed-loop geometry (no inlet/outlet) Gravity enabled (constant/g correctly defined) Initial velocity U = 0 No heat source (temperature and density differences are at numerical-noise level) Constant properties Mesh passes checkMesh without issues Observed behavior During the simulation, p_rgh diverges, and consequently velocity U grows unrealistically |U| reaches 10³–10⁴ m/s, and |∇p_rgh| reaches O(10⁹) Changing p_rgh boundary conditions (zeroGradient, fixedFluxPressure) relaxation factors nNonOrthogonalCorrectors does not improve the behavior Question Are there any known issues, limitations, or required settings in buoyantSimpleFoam that could cause p_rgh to diverge in a closed-loop system with negligible density variation? Any references or similar reported cases would be appreciated. Please note that English is not my first language, and I am still learning OpenFOAM, so I am using a translation tool. Thank you for your understanding. |
Vinayak Ramachandran
Rep Power: 4 ![]() |
Hello Y.T.
It could be because there is no divScheme defined for the pressure field in your fvSchemes. |
| Tags |
| buoyantsimplefoam, openfoam v2412, p_rgh, p_rgh devergence |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 5 | November 22, 2024 07:32 |
| Error SIGSEGV using VOF and UDF | JERC_UTFSM | Fluent UDF and Scheme Programming | 14 | November 8, 2021 00:17 |
| Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
| [ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
| fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 17:08 |
